microSD write operation hangs on P4080
Question asked by Yogesh Ahire on Nov 14, 2013
Latest reply on Aug 24, 2016 by Diego Warszawski
Hi All,
We are using Kernel 3.0.34 ( from SDK 1.2) on our  P4080 board. We are using microSD card and have our filesystem on it.
The Write operation on SD card randomly hangs and eventually Kernel causes following exception, The same can be reproduce if we write continuously on uSD card with dd command.
INFO: task dd:2184 blocked for more than 120 seconds.
"echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
dd              D 0ff1d604     0  2184   2163 0x00000000
Call Trace:
[c7401940] [00000003] 0x3 (unreliable)
[c7401a00] [c0007654] __switch_to+0x94/0xc0
[c7401a20] [c0607068] __schedule+0x268/0x610
[c7401b50] [c0607860] schedule+0x30/0xd0
[c7401b60] [c01ac8d4] do_get_write_access+0x2c4/0x470
[c7401bd0] [c01acc00] jbd2_journal_get_write_access+0x30/0x60
[c7401be0] [c0191658] __ext4_journal_get_write_access+0x38/0xa0
[c7401c00] [c0174010] ext4_reserve_inode_write+0x90/0xc0
[c7401c20] [c0174068] ext4_mark_inode_dirty+0x28/0x1b0
[c7401c50] [c0179718] ext4_dirty_inode+0x38/0x70
[c7401c60] [c010ca3c] __mark_inode_dirty+0x3c/0x220
[c7401c80] [c0117294] generic_write_end+0xe4/0x110
[c7401ca0] [c0177ad4] ext4_da_write_end+0x1a4/0x370
[c7401ce0] [c00a637c] generic_file_buffered_write+0xdc/0x230
[c7401d50] [c00a6ef8] __generic_file_aio_write+0x238/0x4d0
[c7401dc0] [c00a7218] generic_file_aio_write+0x88/0x150
[c7401e10] [c016cff4] ext4_file_write+0x134/0x330
[c7401e60] [c00e2c68] do_sync_write+0xa8/0x130
[c7401ef0] [c00e35a8] vfs_write+0xa8/0x1a0
[c7401f10] [c00e391c] sys_write+0x4c/0x90
[c7401f40] [c000f340] ret_from_syscall+0x0/0x3c
--- Exception: c01 at 0xff1d604
    LR = 0x100044c8
Kernel panic - not syncing: hung_task: blocked tasks
Call Trace:
[e6743ea0] [c0007d64] show_stack+0x44/0x160 (unreliable)
[e6743ee0] [c060a4d0] panic+0xac/0x1ec
[e6743f40] [c008f254] watchdog+0x254/0x270
[e6743fa0] [c0065fdc] kthread+0x7c/0x80
[e6743ff0] [c000e208] kernel_thread+0x4c/0x68
More Information::::
After looking into uSD card messages ( enabled SD/MMC debug logs) the SD card continuously responds with following messages and never completes its write operation,
mmc0: starting CMD13 arg aaaa0000 flags 00000195
sdhci [sdhci_irq()]: *** mmc0 got interrupt: 0x00000001
mmc0: req done (CMD13): 0: 00000c00 00000000 00000000 00000000
I am using Kingston 8GB and tried other cards like Toshiba, Lexar etc they all fails at some point of time.
Any help will be highly appreciated, this is causing us major block now.
Yogesh
