I am trying to develop a web server and put all the web page files in the SD card. But when I read MQXRTCS.pdf, there is no enough information about it.
And then I read the code in web_hvac, but still can not understand it.
Is there a document about this?
Thanks.
Solved! Go to Solution.
The explanation on how to run the web_hvac example is described in the MQX RTOS—Lab Tutorials document. This document can be found in the following link:
http://www.freescale.com/files/soft_dev_tools/doc/support_info/MQXTUTORIALLAB.pdf?fpsp=1
please check the attachment you can find two documents: The MQX from Zero doc is an introduction to the HVAC Demo, And the AN3907 I
