I cannot understand the relations of FB_TA and the state of the bus cycle.
When auto-acknowledge disable ( AA = 0 ) ,
does it continue the current state (S1) until FB_TA becomes Low ?
If FB_TA becomes Low, is it changed by the next state (S2) ?
Solved! Go to Solution.
Yes, your understanding is correct.
If FB_TA is recognized asserted(driven low internally or externally), then the cycle moves on to S2. If FB_TA is not asserted internally or externally, then the S1 state continues to repeat.
Hope that makes sense,
B.R
Kan
B.R
Kan
Thank you for answer.
Another one point let me ask you a question.
Is the following description a mistake?
in "Freescale Semiconductor Document Number: AN4393 Application Note Rev. 0, 05/2012"
2.1 Read cycle
4.
"If the auto-acknowledge feature is disabled (CSCRn[AA] = 0), then FB_TA must be negated 13.5 ns (FB4) before the third cycle."
Hi ,
I think the above description means if you want to put the FlexBus into next stage, FB_TA must be negated 13.5 ns (FB4) before the third cycle when auto-acknowledge feature is disabled.
B.R
Kan
Thank you for your answer.
