S08MP16 Fault Interrupt not working
Question asked by Abhijit Jagtap on Nov 8, 2013
Latest reply on Nov 10, 2013 by Abhijit Jagtap
Hello
Somehow it isn't working now on a final board.Earlier on a perf board it worked every time the pin was fed with a 5v signal.
Now no interrupt is asserted.
Can the pin have become faulty? i have pulled the pin low with external resistor to avoid spurious glitches.
Here is my part of fault init code
    FTM2MODE = 0xC5;
    FTM2FLTCTRL  = 0x11;  //Fault 0 and Filter 0 enabled
    FTM2FAULTFILTER_FFVAL = 0x0F; // FFVAL x system clock = 0.9us
heres the ISR
void interrupt 4 FTM2FAULT_ISR (void)
   FTM2OUTMASK = 0x3F; //stop channels
   FTM2FMS_FAULTF = 0;
what is wrong? can someone point out?
