If you search my posts you will see a lot that discuss Interrupts. You can also search for ISR, Interrupt, Handler and these will give you quite a lot of results.
If you want to know how to declare an interrupt handler in C, we need to know the compiler. It is different in CodeWarrior and GCC.
Paul.
