I'm working on a design with iMX6 that uses DDR3 memory. I'm wondering if it's recommended to do oscilloscope measurements on the DDR3 bus to verify its robustness, or if it is sufficient to just see that it is possible to read and write from it.
Thanks for your help!
I'm testing a embedded SBC using imx6Q5, with 1G of DDR3. RAM Stress Test failed DSQ cal. What oscilloscope is recommended fro checking eye-diagram?
