mfg tool problem on imx6
kylekenj
When I use the mfg tool it has an error at Formatting rootfs partition when trying to program an imx6. Any ideas on what the problem might be? Thanks.
Labels (2)
brajeshsharma
Hi Kyle ,
Can you tell me what steps exacty did you follow to load images on SD card by MFGTool cause i'v followed almost all of them available but cant get even u-boot prompt .  i am using SD3 slot on SabreSD imx6q. when i try the steps it doesnt throw any error says "Done" but when i checkout the card it doesnt have any partitions . so i think i am doing a blunder somewhere It w'd be great if you can guide what exactly you did . and tell me the images also , specially u-boot that you are telling i'v tried with 2-3 u-boot images available for imx .
Thanks & Regards
Brajesh
LeonardoSandova
Specialist I
Post the console's log and the flash commands (the XML profile).
Leo
kylekenj
Wasn't seeing anything in the console yet. The XML profile was
</LIST>
  <LIST name="ubuntu-SabreSD-SD" desc="Choose eMMC android as media">
    <CMD state="BootStrap" type="boot" body="BootStrap" file ="u-boot-mx6q-sabresd.bin" >Loading U-boot</CMD>
    <CMD state="BootStrap" type="load" file="uImage" address="0x10800000"
        loadSection="OTH" setSection="OTH" HasFlashHeader="FALSE" >Loading Kernel.</CMD>
    <CMD state="BootStrap" type="load" file="initramfs.cpio.gz.uboot" address="0x10C00000"
        loadSection="OTH" setSection="OTH" HasFlashHeader="FALSE" >Loading Initramfs.</CMD>
    <CMD state="BootStrap" type="jump" > Jumping to OS image. </CMD>
    <CMD state="Updater" type="push" body="$ ls /dev/*"/>
    <CMD state="Updater" type="push" body="$ dd if=/dev/zero of=/dev/mmcblk0 bs=512 seek=1536 count=16">clean up u-boot parameter</CMD>
    <CMD state="Updater" type="push" body="send" file="files/u-boot-mx6q-sabresd.bin">Sending U-Boot</CMD>
    <CMD state="Updater" type="push" body="$ dd if=$FILE of=/dev/mmcblk0 bs=512 seek=2 skip=2">write U-Boot to sd card</CMD>
    <CMD state="Updater" type="push" body="send" file="files/uImage">Sending kernel uImage</CMD>
    <CMD state="Updater" type="push" body="$ dd if=$FILE of=/dev/mmcblk0 bs=1M seek=1 conv=fsync">write kernel image to sd card</CMD>
    <CMD state="Updater" type="push" body="send" file="mksdcard.sh.tar">Sending partition shell</CMD>
    <CMD state="Updater" type="push" body="$ tar xf $FILE "> Partitioning...</CMD>
    <CMD state="Updater" type="push" body="$ sh mksdcard.sh /dev/mmcblk0"> Partitioning...</CMD>
    <CMD state="Updater" type="push" body="$ mkfs.ext3 -j /dev/mmcblk0p1">Formatting rootfs partition</CMD>
    <CMD state="Updater" type="push" body="$ mkdir -p /mnt/mmcblk0p1"/>
    <CMD state="Updater" type="push" body="$ mount -t ext3 /dev/mmcblk0p1 /mnt/mmcblk0p1"/>
    <CMD state="Updater" type="push" body="pipe tar --numeric-owner -zxv -C /mnt/mmcblk0p1" file="files/oneiric.tgz">Sending and writting rootfs</CMD>
    <CMD state="Updater" type="push" body="frf">Finishing rootfs write</CMD>
    <CMD state="Updater" type="push" body="$ umount /mnt/mmcblk0p1">Unmounting rootfs partition</CMD>
    <CMD state="Updater" type="push" body="$ echo Update Complete!">Done</CMD>
</LIST>
LeonardoSandova
Specialist I
Nothing comes out from the serial console? You should see the error either on the serial console or the log produced on the MFGtool.
Make sure you have all the files values (i.e. file="file/oneiric.tgz") and a SD with at least 4GB.
Leo
kylekenj
Here is the log from the MFGtool
DLL version: 2.1.1
Wednesday, November 06, 2013 12:52:58   Start new logging
ModuleID[1] LevelID[10]: Parse C:\Users\Kyle\Downloads\Mfgtools-Rel-4.0.0_130424_MX6Q_UPDATER.tar\Mfgtools-Rel-4.0.0_130424_MX6Q_UPDATER\Mfgtools-Rel-4.0.0_130424_MX6Q_UPDATER\cfg.ini file success[chip: MX6Q Linux Update, List: ubuntu-SabreSD-SD]
ModuleID[1] LevelID[10]: Parse C:\Users\Kyle\Downloads\Mfgtools-Rel-4.0.0_130424_MX6Q_UPDATER.tar\Mfgtools-Rel-4.0.0_130424_MX6Q_UPDATER\Mfgtools-Rel-4.0.0_130424_MX6Q_UPDATER\Profiles\MX6Q Linux Update\OS Firmware\ucl2.xml file success
ModuleID[2] LevelID[10]: CMyExceptionHandler thread is running
ModuleID[2] LevelID[1]: new MxHidDeviceClass
ModuleID[2] LevelID[10]: new MxHidDevice[00465428]
ModuleID[2] LevelID[10]: DeviceTypeDisk--_devices size: 1
ModuleID[2] LevelID[10]: Volume--StorageDisk, Disk->_driveNumber:1, Volume->_diskNumber:1
ModuleID[2] LevelID[10]: DeviceTypeDisk--find Disk device: 0046A428
ModuleID[2] LevelID[10]: Device::hubIndex::getmsc, return the port index is: 3
ModuleID[2] LevelID[10]: Device Manager thread is running
ModuleID[1] LevelID[10]: Initialize Device Manager success
ModuleID[2] LevelID[10]: CmdOperation[0] device chagned and reset to state 0
ModuleID[2] LevelID[10]: ExecuteCommand--Boot[WndIndex:0], File is C:\Users\Kyle\Downloads\Mfgtools-Rel-4.0.0_130424_MX6Q_UPDATER.tar\Mfgtools-Rel-4.0.0_130424_MX6Q_UPDATER\Mfgtools-Rel-4.0.0_130424_MX6Q_UPDATER\Profiles\MX6Q Linux Update\OS Firmware\u-boot-mx6q-sabresd.bin
ModuleID[2] LevelID[10]: ExecuteCommand--Load[WndIndex:0], File is C:\Users\Kyle\Downloads\Mfgtools-Rel-4.0.0_130424_MX6Q_UPDATER.tar\Mfgtools-Rel-4.0.0_130424_MX6Q_UPDATER\Mfgtools-Rel-4.0.0_130424_MX6Q_UPDATER\Profiles\MX6Q Linux Update\OS Firmware\uImage, address is 0x10800000
ModuleID[2] LevelID[10]: PortMgrDlg(0)--Command Load excute successfully, retry count: 0
ModuleID[2] LevelID[10]: ExecuteCommand--Load[WndIndex:0], File is C:\Users\Kyle\Downloads\Mfgtools-Rel-4.0.0_130424_MX6Q_UPDATER.tar\Mfgtools-Rel-4.0.0_130424_MX6Q_UPDATER\Mfgtools-Rel-4.0.0_130424_MX6Q_UPDATER\Profiles\MX6Q Linux Update\OS Firmware\initramfs.cpio.gz.uboot, address is 0x10C00000
ModuleID[2] LevelID[10]: ExecuteCommand--Jump[WndIndex:0]
ModuleID[2] LevelID[10]: *********MxHidDevice[00465428] Jump to Ramkernel successfully!**********
ModuleID[2] LevelID[10]: CmdOperation[0], current state command has been finished and the last command is successful, so SetEvent(hDevCanDeleteEvent)
ModuleID[2] LevelID[10]: DeviceManager::DevChangeWnd::OnDeviceChange() - DEVICE_REMOVAL_EVT(\\?\USB#VID_15A2&PID_0054#5&361c14bc&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed})
ModuleID[2] LevelID[10]: DeviceManager::DevChangeWnd::OnDeviceChange() - end
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - DEVICE_REMOVAL_EVT(\\?\USB#VID_15A2&PID_0054#5&361c14bc&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed})
ModuleID[2] LevelID[10]: DeviceClass::FindDeviceByUsbPath--DeviceListType_Current, _devices.size: 1
ModuleID[2] LevelID[10]: DeviceClass::FindDeviceByUsbPath--DeviceListType_Current, devInstPathToFind: USB\VID_15A2&PID_0054\5&361C14BC&0&1, _deviceInstanceID: USB\VID_15A2&PID_0054\5&361C14BC&0&1
ModuleID[2] LevelID[10]: DeviceClass::FindDeviceByUsbPath--DeviceListType_Current, Find the device
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - DEVICE_REMOVAL_EVT,[MxHidDeviceClass] vid_15a2&pid_0054, Hub:6-Port:1
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - DEVICE_REMOVAL_EVT, Notify
ModuleID[2] LevelID[10]: CmdOpreation[0]--OnDeviceChangeNotify, Volume Arrive/Remove or Device Arrive/Remove
ModuleID[2] LevelID[10]: CmdOpreation[0]--OnDeviceChangeNotify, m_p_usb_port is not NULL, so only refresh
ModuleID[2] LevelID[10]: CmdOpreation[0]--OnDeviceChangeNotify, Volume/Device Remove
ModuleID[2] LevelID[1]: CmdOpreation[0]--set m_hDeviceRemoveEvent.
ModuleID[2] LevelID[10]: CmdOpreation[0]--WaitforEvents device remove1
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent()-DEVICE_REMOVAL_EVT, hDevCanDeleteEvent has been set
ModuleID[2] LevelID[10]: delete MxHidDevice[00465428]
ModuleID[2] LevelID[10]: DeviceManager::DevChangeWnd::OnDeviceChange() - DEVICE_ARRIVAL_EVT(\\?\USB#VID_066F&PID_37FF#5&361c14bc&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed})
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - DEVICE_ARRIVAL_EVT(\\?\USB#VID_066F&PID_37FF#5&361c14bc&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed})
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - DEVICE_ARRIVAL_EVT,[Msc,DiskDeviceClass] vid_066f&pid_37ff, not handled
ModuleID[2] LevelID[10]: DeviceManager::DevChangeWnd::OnDeviceChange() - VOLUME_ARRIVAL_EVT(D)
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - VOLUME_ARRIVAL_EVT(D)
ModuleID[2] LevelID[10]: VolumeDeviceClass::AddUsbDevice()  D
ModuleID[2] LevelID[10]: DeviceTypeDisk--_devices size: 2
ModuleID[2] LevelID[10]: Volume--StorageDisk, Disk->_driveNumber:1, Volume->_diskNumber:2
ModuleID[2] LevelID[10]: Volume--StorageDisk, Disk->_driveNumber:2, Volume->_diskNumber:2
ModuleID[2] LevelID[10]: DeviceTypeDisk--find Disk device: 00473D88
ModuleID[2] LevelID[10]: Device::hubIndex::getmsc, return the port index is: 1
ModuleID[2] LevelID[10]: VolumeDeviceClass::AddUsbDevice() successful D add to current list, retrycount: 0
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - VOLUME_ARRIVAL_EVT-Disk(D), Hub:6-Port:1
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - VOLUME_ARRIVAL_EVT, Notify
ModuleID[2] LevelID[10]: CmdOpreation[0]--OnDeviceChangeNotify, Volume/Device Arrive
ModuleID[2] LevelID[1]: CmdOpreation[0]--set m_hDeviceArriveEvent.
ModuleID[2] LevelID[10]: CmdOpreation[0]--WaitforEvents device arrive1
ModuleID[2] LevelID[10]: CmdOperation[0] device chagned and reset to state 1
ModuleID[2] LevelID[10]: ExecuteCommand--Push[WndIndex:0], Body is $ ls /dev/*
ModuleID[2] LevelID[10]: ExecuteCommand--Push[WndIndex:0], Body is $ dd if=/dev/zero of=/dev/mmcblk0 bs=512 seek=1536 count=16
ModuleID[2] LevelID[10]: ExecuteCommand--Push[WndIndex:0], Body is send
ModuleID[2] LevelID[10]: ExecuteCommand--Push[WndIndex:0], Body is $ dd if=$FILE of=/dev/mmcblk0 bs=512 seek=2 skip=2
ModuleID[2] LevelID[10]: ExecuteCommand--Push[WndIndex:0], Body is $ dd if=$FILE of=/dev/mmcblk0 bs=1M seek=1 conv=fsync
ModuleID[2] LevelID[10]: ExecuteCommand--Push[WndIndex:0], Body is $ tar xf $FILE
ModuleID[2] LevelID[10]: ExecuteCommand--Push[WndIndex:0], Body is $ sh mksdcard.sh /dev/mmcblk0
ModuleID[2] LevelID[10]: ExecuteCommand--Push[WndIndex:0], Body is $ mkfs.ext3 -j /dev/mmcblk0p1
ModuleID[2] LevelID[1]: PortMgrDlg(0)--MxHidDevice--Command Push(no file) excute failed
ModuleID[2] LevelID[10]: CmdOperation[0], current command executed failed, so SetEvent(hDevCanDeleteEvent)
ModuleID[2] LevelID[10]: CCmdOpreation[0] thread is Closed
ModuleID[2] LevelID[10]: CCmdOpreation thread is Closed
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - EVENT_KILL
ModuleID[2] LevelID[10]: CMyExceptionHandler::OnMsgExceptionEvent() - KillExceptionHandlerThread
ModuleID[2] LevelID[10]: Exception Handler thread is closed
ModuleID[2] LevelID[1]: delete MxHidDeviceClass
ModuleID[2] LevelID[10]: Device Manager thread is closed
LeonardoSandova
Specialist I
Seems that you dont have the files/oneiric.tgz file. Make sure you have it on the correct path and double check the file can be untar on your host.
Leo
kylekenj
I put a files/oneiric.tgz file in before and double checked the path. I was able to get the terminal working finally here is the feedback from that.
UTP: received command '$ ls /dev/*'
UTP: executing "ls /dev/*"
/dev/XOR                 /dev/ptyua               /dev/ttydb
/dev/apm_bios            /dev/ptyub               /dev/ttydc
/dev/console             /dev/ptyuc               /dev/ttydd
/dev/cpu_dma_latency     /dev/ptyud               /dev/ttyde
/dev/crypto              /dev/ptyue               /dev/ttydf
/dev/fb                  /dev/ptyuf               /dev/ttye0
/dev/fb0                 /dev/ptyv0               /dev/ttye1
/dev/fb1                 /dev/ptyv1               /dev/ttye2
/dev/fb2                 /dev/ptyv2               /dev/ttye3
/dev/fb3                 /dev/ptyv3               /dev/ttye4
/dev/fb4                 /dev/ptyv4               /dev/ttye5
/dev/full                /dev/ptyv5               /dev/ttye6
/dev/i2c-0               /dev/ptyv6               /dev/ttye7
/dev/i2c-1               /dev/ptyv7               /dev/ttye8
/dev/i2c-2               /dev/ptyv8               /dev/ttye9
/dev/kmem                /dev/ptyv9               /dev/ttyea
/dev/kmsg                /dev/ptyva               /dev/ttyeb
/dev/loop0               /dev/ptyvb               /dev/ttyec
/dev/loop1               /dev/ptyvc               /dev/ttyed
/dev/loop2               /dev/ptyvd               /dev/ttyee
/dev/loop3               /dev/ptyve               /dev/ttyef
/dev/loop4               /dev/ptyvf               /dev/ttymxc0
/dev/loop5               /dev/ptyw0               /dev/ttymxc1
/dev/loop6               /dev/ptyw1               /dev/ttyp0
/dev/loop7               /dev/ptyw2               /dev/ttyp1
/dev/mem                 /dev/ptyw3               /dev/ttyp2
/dev/mmcblk0             /dev/ptyw4               /dev/ttyp3
/dev/mmcblk1             /dev/ptyw5               /dev/ttyp4
/dev/mtd0                /dev/ptyw6               /dev/ttyp5
/dev/mtd0ro              /dev/ptyw7               /dev/ttyp6
/dev/mtd1                /dev/ptyw8               /dev/ttyp7
/dev/mtd1ro              /dev/ptyw9               /dev/ttyp8
/dev/mtdblock0           /dev/ptywa               /dev/ttyp9
/dev/mtdblock1           /dev/ptywb               /dev/ttypa
/dev/mxc_asrc            /dev/ptywc               /dev/ttypb
/dev/mxc_hdmi            /dev/ptywd               /dev/ttypc
/dev/mxc_ipu             /dev/ptywe               /dev/ttypd
/dev/mxc_mem             /dev/ptywf               /dev/ttype
/dev/mxc_vpu             /dev/ptyx0               /dev/ttypf
/dev/mxs_viim            /dev/ptyx1               /dev/ttyq0
/dev/network_latency     /dev/ptyx2               /dev/ttyq1
/dev/network_throughput  /dev/ptyx3               /dev/ttyq2
/dev/null                /dev/ptyx4               /dev/ttyq3
/dev/psaux               /dev/ptyx5               /dev/ttyq4
/dev/ptmx                /dev/ptyx6               /dev/ttyq5
/dev/ptya0               /dev/ptyx7               /dev/ttyq6
/dev/ptya1               /dev/ptyx8               /dev/ttyq7
/dev/ptya2               /dev/ptyx9               /dev/ttyq8
/dev/ptya3               /dev/ptyxa               /dev/ttyq9
/dev/ptya4               /dev/ptyxb               /dev/ttyqa
/dev/ptya5               /dev/ptyxc               /dev/ttyqb
/dev/ptya6               /dev/ptyxd               /dev/ttyqc
/dev/ptya7               /dev/ptyxe               /dev/ttyqd
/dev/ptya8               /dev/ptyxf               /dev/ttyqe
/dev/ptya9               /dev/ptyy0               /dev/ttyqf
/dev/ptyaa               /dev/ptyy1               /dev/ttyr0
/dev/ptyab               /dev/ptyy2               /dev/ttyr1
/dev/ptyac               /dev/ptyy3               /dev/ttyr2
/dev/ptyad               /dev/ptyy4               /dev/ttyr3
/dev/ptyae               /dev/ptyy5               /dev/ttyr4
/dev/ptyaf               /dev/ptyy6               /dev/ttyr5
/dev/ptyb0               /dev/ptyy7               /dev/ttyr6
/dev/ptyb1               /dev/ptyy8               /dev/ttyr7
/dev/ptyb2               /dev/ptyy9               /dev/ttyr8
/dev/ptyb3               /dev/ptyya               /dev/ttyr9
/dev/ptyb4               /dev/ptyyb               /dev/ttyra
/dev/ptyb5               /dev/ptyyc               /dev/ttyrb
/dev/ptyb6               /dev/ptyyd               /dev/ttyrc
/dev/ptyb7               /dev/ptyye               /dev/ttyrd
/dev/ptyb8               /dev/ptyyf               /dev/ttyre
/dev/ptyb9               /dev/ptyz0               /dev/ttyrf
/dev/ptyba               /dev/ptyz1               /dev/ttys0
/dev/ptybb               /dev/ptyz2               /dev/ttys1
/dev/ptybc               /dev/ptyz3               /dev/ttys2
/dev/ptybd               /dev/ptyz4               /dev/ttys3
/dev/ptybe               /dev/ptyz5               /dev/ttys4
/dev/ptybf               /dev/ptyz6               /dev/ttys5
/dev/ptyc0               /dev/ptyz7               /dev/ttys6
/dev/ptyc1               /dev/ptyz8               /dev/ttys7
/dev/ptyc2               /dev/ptyz9               /dev/ttys8
/dev/ptyc3               /dev/ptyza               /dev/ttys9
/dev/ptyc4               /dev/ptyzb               /dev/ttysa
/dev/ptyc5               /dev/ptyzc               /dev/ttysb
/dev/ptyc6               /dev/ptyzd               /dev/ttysc
/dev/ptyc7               /dev/ptyze               /dev/ttysd
/dev/ptyc8               /dev/ptyzf               /dev/ttyse
/dev/ptyc9               /dev/random              /dev/ttysf
/dev/ptyca               /dev/rfkill              /dev/ttyt0
/dev/ptycb               /dev/rtc                 /dev/ttyt1
/dev/ptycc               /dev/rtc0                /dev/ttyt2
/dev/ptycd               /dev/tracebuf            /dev/ttyt3
/dev/ptyce               /dev/tty                 /dev/ttyt4
/dev/ptycf               /dev/tty0                /dev/ttyt5
/dev/ptyd0               /dev/tty1                /dev/ttyt6
/dev/ptyd1               /dev/tty10               /dev/ttyt7
/dev/ptyd2               /dev/tty11               /dev/ttyt8
/dev/ptyd3               /dev/tty12               /dev/ttyt9
/dev/ptyd4               /dev/tty13               /dev/ttyta
/dev/ptyd5               /dev/tty14               /dev/ttytb
/dev/ptyd6               /dev/tty15               /dev/ttytc
/dev/ptyd7               /dev/tty16               /dev/ttytd
/dev/ptyd8               /dev/tty17               /dev/ttyte
/dev/ptyd9               /dev/tty18               /dev/ttytf
/dev/ptyda               /dev/tty19               /dev/ttyu0
/dev/ptydb               /dev/tty2                /dev/ttyu1
/dev/ptydc               /dev/tty20               /dev/ttyu2
/dev/ptydd               /dev/tty21               /dev/ttyu3
/dev/ptyde               /dev/tty22               /dev/ttyu4
/dev/ptydf               /dev/tty23               /dev/ttyu5
/dev/ptye0               /dev/tty24               /dev/ttyu6
/dev/ptye1               /dev/tty25               /dev/ttyu7
/dev/ptye2               /dev/tty26               /dev/ttyu8
/dev/ptye3               /dev/tty27               /dev/ttyu9
/dev/ptye4               /dev/tty28               /dev/ttyua
/dev/ptye5               /dev/tty29               /dev/ttyub
/dev/ptye6               /dev/tty3                /dev/ttyuc
/dev/ptye7               /dev/tty30               /dev/ttyud
/dev/ptye8               /dev/tty31               /dev/ttyue
/dev/ptye9               /dev/tty32               /dev/ttyuf
/dev/ptyea               /dev/tty33               /dev/ttyv0
/dev/ptyeb               /dev/tty34               /dev/ttyv1
/dev/ptyec               /dev/tty35               /dev/ttyv2
/dev/ptyed               /dev/tty36               /dev/ttyv3
/dev/ptyee               /dev/tty37               /dev/ttyv4
/dev/ptyef               /dev/tty38               /dev/ttyv5
/dev/ptyp0               /dev/tty39               /dev/ttyv6
/dev/ptyp1               /dev/tty4                /dev/ttyv7
/dev/ptyp2               /dev/tty40               /dev/ttyv8
/dev/ptyp3               /dev/tty41               /dev/ttyv9
/dev/ptyp4               /dev/tty42               /dev/ttyva
/dev/ptyp5               /dev/tty43               /dev/ttyvb
/dev/ptyp6               /dev/tty44               /dev/ttyvc
/dev/ptyp7               /dev/tty45               /dev/ttyvd
/dev/ptyp8               /dev/tty46               /dev/ttyve
/dev/ptyp9               /dev/tty47               /dev/ttyvf
/dev/ptypa               /dev/tty48               /dev/ttyw0
/dev/ptypb               /dev/tty49               /dev/ttyw1
/dev/ptypc               /dev/tty5                /dev/ttyw2
/dev/ptypd               /dev/tty50               /dev/ttyw3
/dev/ptype               /dev/tty51               /dev/ttyw4
/dev/ptypf               /dev/tty52               /dev/ttyw5
/dev/ptyq0               /dev/tty53               /dev/ttyw6
/dev/ptyq1               /dev/tty54               /dev/ttyw7
/dev/ptyq2               /dev/tty55               /dev/ttyw8
/dev/ptyq3               /dev/tty56               /dev/ttyw9
/dev/ptyq4               /dev/tty57               /dev/ttywa
/dev/ptyq5               /dev/tty58               /dev/ttywb
/dev/ptyq6               /dev/tty59               /dev/ttywc
/dev/ptyq7               /dev/tty6                /dev/ttywd
/dev/ptyq8               /dev/tty60               /dev/ttywe
/dev/ptyq9               /dev/tty61               /dev/ttywf
/dev/ptyqa               /dev/tty62               /dev/ttyx0
/dev/ptyqb               /dev/tty63               /dev/ttyx1
/dev/ptyqc               /dev/tty7                /dev/ttyx2
/dev/ptyqd               /dev/tty8                /dev/ttyx3
/dev/ptyqe               /dev/tty9                /dev/ttyx4
/dev/ptyqf               /dev/ttya0               /dev/ttyx5
/dev/ptyr0               /dev/ttya1               /dev/ttyx6
/dev/ptyr1               /dev/ttya2               /dev/ttyx7
/dev/ptyr2               /dev/ttya3               /dev/ttyx8
/dev/ptyr3               /dev/ttya4               /dev/ttyx9
/dev/ptyr4               /dev/ttya5               /dev/ttyxa
/dev/ptyr5               /dev/ttya6               /dev/ttyxb
/dev/ptyr6               /dev/ttya7               /dev/ttyxc
/dev/ptyr7               /dev/ttya8               /dev/ttyxd
/dev/ptyr8               /dev/ttya9               /dev/ttyxe
/dev/ptyr9               /dev/ttyaa               /dev/ttyxf
/dev/ptyra               /dev/ttyab               /dev/ttyy0
/dev/ptyrb               /dev/ttyac               /dev/ttyy1
/dev/ptyrc               /dev/ttyad               /dev/ttyy2
/dev/ptyrd               /dev/ttyae               /dev/ttyy3
/dev/ptyre               /dev/ttyaf               /dev/ttyy4
/dev/ptyrf               /dev/ttyb0               /dev/ttyy5
/dev/ptys0               /dev/ttyb1               /dev/ttyy6
/dev/ptys1               /dev/ttyb2               /dev/ttyy7
/dev/ptys2               /dev/ttyb3               /dev/ttyy8
/dev/ptys3               /dev/ttyb4               /dev/ttyy9
/dev/ptys4               /dev/ttyb5               /dev/ttyya
/dev/ptys5               /dev/ttyb6               /dev/ttyyb
/dev/ptys6               /dev/ttyb7               /dev/ttyyc
/dev/ptys7               /dev/ttyb8               /dev/ttyyd
/dev/ptys8               /dev/ttyb9               /dev/ttyye
/dev/ptys9               /dev/ttyba               /dev/ttyyf
/dev/ptysa               /dev/ttybb               /dev/ttyz0
/dev/ptysb               /dev/ttybc               /dev/ttyz1
/dev/ptysc               /dev/ttybd               /dev/ttyz2
/dev/ptysd               /dev/ttybe               /dev/ttyz3
/dev/ptyse               /dev/ttybf               /dev/ttyz4
/dev/ptysf               /dev/ttyc0               /dev/ttyz5
/dev/ptyt0               /dev/ttyc1               /dev/ttyz6
/dev/ptyt1               /dev/ttyc2               /dev/ttyz7
/dev/ptyt2               /dev/ttyc3               /dev/ttyz8
/dev/ptyt3               /dev/ttyc4               /dev/ttyz9
/dev/ptyt4               /dev/ttyc5               /dev/ttyza
/dev/ptyt5               /dev/ttyc6               /dev/ttyzb
/dev/ptyt6               /dev/ttyc7               /dev/ttyzc
/dev/ptyt7               /dev/ttyc8               /dev/ttyzd
/dev/ptyt8               /dev/ttyc9               /dev/ttyze
/dev/ptyt9               /dev/ttyca               /dev/ttyzf
/dev/ptyta               /dev/ttycb               /dev/ubi_ctrl
/dev/ptytb               /dev/ttycc               /dev/urandom
/dev/ptytc               /dev/ttycd               /dev/utp
/dev/ptytd               /dev/ttyce               /dev/vcs
/dev/ptyte               /dev/ttycf               /dev/vcs1
/dev/ptytf               /dev/ttyd0               /dev/vcsa
/dev/ptyu0               /dev/ttyd1               /dev/vcsa1
/dev/ptyu1               /dev/ttyd2               /dev/vhci
/dev/ptyu2               /dev/ttyd3               /dev/video16
/dev/ptyu3               /dev/ttyd4               /dev/video17
/dev/ptyu4               /dev/ttyd5               /dev/video18
/dev/ptyu5               /dev/ttyd6               /dev/video19
/dev/ptyu6               /dev/ttyd7               /dev/video20
/dev/ptyu7               /dev/ttyd8               /dev/watchdog
/dev/ptyu8               /dev/ttyd9               /dev/zero
/dev/ptyu9               /dev/ttyda
/dev/disk:
by-path
/dev/input:
mice    uinput
/dev/pts:
/dev/shm:
/dev/snd:
timer
UTP: sending Success to kernel for command $ ls /dev/*.
utp_poll: pass returned.
UTP: received command '$ dd if=/dev/zero of=/dev/mmcblk0 bs=512 seek=1536 count=16'
UTP: executing "dd if=/dev/zero of=/dev/mmcblk0 bs=512 seek=1536 count=16"
16+0 records in
16+0 records out
8192 bytes (8.0KB) copied, 0.000189 seconds, 41.3MB/s
UTP: sending Success to kernel for command $ dd if=/dev/zero of=/dev/mmcblk0 bs=512 seek=1536 count=16.
UTP: received command 'send'
UTP: sending Success to kernel for command send.
UTP: received command '$ dd if=$FILE of=/dev/mmcblk0 bs=512 seek=2 skip=2'
UTP: executing "dd if=$FILE of=/dev/mmcblk0 bs=512 seek=2 skip=2"
841+1 records in
841+1 records out
430672 bytes (420.6KB) copied, 0.005657 seconds, 72.6MB/s
UTP: sending Success to kernel for command $ dd if=$FILE of=/dev/mmcblk0 bs=512 seek=2 skip=2.
UTP: received command '$ dd if=$FILE of=/dev/mmcblk0 bs=1M seek=1 conv=fsync'
UTP: executing "dd if=$FILE of=/dev/mmcblk0 bs=1M seek=1 conv=fsync"
3+1 records in
3+1 records out
3866508 bytes (3.7MB) copied, 0.026597 seconds, 138.6MB/s
UTP: sending Success to kernel for command $ dd if=$FILE of=/dev/mmcblk0 bs=1M seek=1 conv=fsync.
UTP: received command '$ tar xf $FILE '
UTP: executing "tar xf $FILE "
UTP: sending Success to kernel for command $ tar xf $FILE .
UTP: received command '$ sh mksdcard.sh /dev/mmcblk0'
UTP: executing "sh mksdcard.sh /dev/mmcblk0"
1+0 records in
1+0 records out
1024 bytes (1.0KB) copied, 0.002075 seconds, 481.9KB/s
Warning: /dev/mmcblk0 is not a block device
Disk /dev/mmcblk0: cannot get geometry
Disk /dev/mmcblk0: 0 cylinders, 255 heads, 63 sectors/track
sfdisk: ERROR: sector 0 does not have an msdos signature
/dev/mmcblk0: unrecognized partition table type
Old situation:
No partitions found
New situation:
Units = mebibytes of 1048576 bytes, blocks of 1024 bytes, counting from 0
   Device Boot Start   End    MiB    #blocks   Id  System
/dev/mmcblk0p1         7+     7-     0          0   83  Linux
/dev/mmcblk0p2         0      -      0          0    0  Empty
/dev/mmcblk0p3         0      -      0          0    0  Empty
/dev/mmcblk0p4         0      -      0          0    0  Empty
Warning: partition 1 has size 0 but is not marked Empty
Warning: no primary partition is marked bootable (active)
This does not matter for LILO, but the DOS MBR will not boot this disk.
Successfully wrote the new partition table
Re-reading the partition table ...
BLKRRPART: Inappropriate ioctl for device
If you created or changed a DOS partition, /dev/foo7, say, then use dd(1)
to zero the first 512 bytes:  dd if=/dev/zero of=/dev/foo7 bs=512 count=1
(See fdisk(8).)
UTP: sending Success to kernel for command $ sh mksdcard.sh /dev/mmcblk0.
UTP: received command '$ mkfs.ext3 -j /dev/mmcblk0p1'
UTP: executing "mkfs.ext3 -j /dev/mmcblk0p1"
mke2fs 1.41.4 (27-Jan-2009)
Could not stat /dev/mmcblk0p1 --- No such file or directory
The device apparently does not exist; did you specify it correctly?
UTP: sending Non-success to kernel for command $ mkfs.ext3 -j /dev/mmcblk0p1.
utp_poll: exit with status 256
LeonardoSandova
Specialist I
Weird. Seems that the SD is not on mmcblk0p1 which I think is the SD2 port (the SD3 is the one closest to the USB serial). Can you try placing the SD in SD2?
Leo
kylekenj
What is the port for SD3?
LeonardoSandova
Specialist I
BTW, which board are you using?
SD3 is J507 and SD2 is J500, this is for the imx6qsabresd.
kylekenj
Got the SD card to read. It says it is read only though.
dd: can't open '/dev/mmcblk0': Read-only file system
UTP: sending Non-success to kernel for command $ dd if=/dev/zero of=/dev/mmcblk0 bs=512 seek=1536 count=16.
LeonardoSandova
Specialist I
If the SD is not locked and if you have tried other SD cards, then I do not know what the problem is...
