EIM_DATA23 is special?
Question asked by john huang on Oct 31, 2013
I created my ownboard based on IMX6Q. I use BSP 13.4.1
from Freescale.
As I saw in the code:
static struct max8903_pdata charger1_data = {
    .dok = SABRESD_CHARGE_DOK_B,
    .uok = SABRESD_CHARGE_UOK_B,
    .chg = SABRESD_CHARGE_CHG_1_B,
    .flt = SABRESD_CHARGE_FLT_1_B,
    .dcm_always_high = true,
    .dc_valid = true,
    .usb_valid = true,
That max8903 use SABRESD_CHARGE_CHG_1_B
(IMX_GPIO_NR(3, 23)) as charger status pin. But on my
board, i used this pin for another purpose (i don't have
max8903 on my board). But when i changed IMX_GPIO_NR(3,
23) to output to adapt my own purpose, kernel stoping.
So i assume that in the kernel booting process, kernel check
the value of this GPIO pin. I disable all items related to
max8903 in imx6_android_defconfig. But kernel still stoping.
So i have a question, how can i use IMX_GPIO_NR(3,23) for
my own purpose.
Original Attachment has been moved to: log-console.txt.zip
