IO_IOCTL_SERIAL_WAIT_FOR_TC behaves strange (MQX4.0)
Question asked by Mikhail Burakov on Oct 29, 2013
Latest reply on Nov 7, 2013 by David Tietz
Hello!
I am trying to implement support for custom protocol working via RS-485. However I stumbled upon a problem with IO_IOCTL_SERIAL_WAIT_FOR_TC. In my configuration I need to switch a gpio pin after all the data has been sent. To ensure all the data is sent, I tried to use the above ioctl. But on the receiving side I do not get the tail of my data, so it looks like the ioctl returns before all the data is sent. However, I figured out that actually this ioctl does nothing other than waiting for the TC bit in UARTx_S1 register in an infinite loop. I simply removed the ioctl call and replaced it with exact the same infinite loop. Everything started to work as expected afterwards. So my question is, how is this possible? I looked through the serial ioctls part of MQX code and did not found any suspicious calls. For the reference, I am running MQX 4.0.1 on MK20DX256VLK7 CPU. Is there anything I missed in the documentation?
Mikhail Burakov
