Use Mouse on i.MX6 SABRE AI
florianl
Hi everybody,
I would like to use an optical mouse on the  i.MX6 SABRE AI. At the moment I'm using the YOCTO build fsl-image-gui from the dylan branch.
I already have the provided usb cable mini->normal attached but the mouse is never activated...
Thanks alot!
Florian
Labels (3)
LeonardoSandova
Specialist I
Is there any log on dmesg's output (kernel log) when you connect it? Does it work on your Linux Host?
Leo
florianl
Hi Leo,
thanks for your quick reply.
No the dmesg doesn't show any output when connecting the mouse. On the host the mouse is working flawlessly Also the otpical mouse light doesn't turn on...
correction/addition to my previous post: I'm using the J10 USB-OTG connector on the CPU board with the provided usb-cable (Micro-B to standard-A cable and A-female to A-female adaptor)
The only usb related outputs in dmesg:
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
IMX usb wakeup probe
usbcore: registered new interface driver btusb
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
usbcore: registered new interface driver snd-usb-audio
