How to configure the P1010 RDB binaries by using the Yocto SDK 1.4?
haowang
Hi, I'm using the Freescale SDK 1.4 to build the kernel of the P1010 RDB. If I use 'bitbake fsl-image-minimal', some u-boot and kernel images will be build.
Now I don't want the Security Engine 4.4 to be activated in the boot, how can I configure this before the kernel is complied?
Thanks for the help.
yipingwang
About how to configure and rebuild Linux Kernel, please try to use the following steps.
1. $ bitbake -c patch virtual/kernel -f
2. Do menuconfig
$ bitbake -c menuconfig virtual/kernel
The following is CAAM configuration options, please disable them.
<*> Freescale CAAM-Multicore driver backend
(9) Job Ring size
[ ] Job Ring interrupt coalescing
<*> Register algorithm implementations with the Crypto API
<*> Register hash algorithm implementations with Crypto API
<*> Register caam device for hwrng API
save the configuration and rebuild Kernel.
$ bitbake -c compile -f virtual/kernel
$ bitbake virtual/kernel
