FRDM complaints about memory inconsistency
Question asked by Kai Liu on Oct 18, 2013
Latest reply on Oct 23, 2013 by Kai Liu
I use IAR and FRDM-KL25Z for my work. I found FRDM-KL25Z always complaints about memory inconsistency at address 0x00000000. The code execution is normal. But it is annoying.
I tried to erase all memory. But it doens't help at all. And I have two boards, they have same issues. Here is my log file. Please comment if you have any ideas about it.
================ IAR Debug Log ==================
Sat Oct 19, 2013 12:18:38: Loaded macro file: C:\Program Files\IAR Systems\Embedded Workbench 6.5\arm\config\flashloader\Freescale\FlashKLxx.mac
Sat Oct 19, 2013 12:18:39: Windows NT detected.
Sat Oct 19, 2013 12:18:43: OpenSDA detected - Flash Version 1.02
Sat Oct 19, 2013 12:18:44: Device is KINETIS.
Sat Oct 19, 2013 12:18:44: Mode is In-Circuit Debug.
Sat Oct 19, 2013 12:18:44: CPU reset by debugger.
Sat Oct 19, 2013 12:18:44: Software reset was performed
Sat Oct 19, 2013 12:18:44: ----- Prepare hardware for Flashloader -----
Sat Oct 19, 2013 12:18:45: 768 bytes downloaded and verified (1.02 Kbytes/sec)
Sat Oct 19, 2013 12:18:45: Loaded debugee: C:\Program Files\IAR Systems\Embedded Workbench 6.5\arm\config\flashloader\Freescale\FlashKLxx16K.out
Sat Oct 19, 2013 12:18:45: Target reset
Sat Oct 19, 2013 12:18:48: Downloaded D:\Freescale FRDM KL25Z\an4379sw_msd_bootloader\Source\Device\app\msd_bootloader\iar_ew\kinetis_l2k\Debug\
Exe\USB_MSD_Bootloader.out to flash memory.
Sat Oct 19, 2013 12:18:51: 22368 bytes downloaded into FLASH and verified (3.77 Kbytes/sec)
Sat Oct 19, 2013 12:18:51: Warning: Target inconsistency detected at Memory address 0x00000000
Sat Oct 19, 2013 12:18:53: Warning: There were warnings during download, see Log Window
Sat Oct 19, 2013 12:18:53: Loaded debugee: D:\Freescale FRDM KL25Z\an4379sw_msd_bootloader\Source\Device\app\msd_bootloader\iar_ew\kinetis_l2k\
Debug\Exe\USB_MSD_Bootloader.out
Sat Oct 19, 2013 12:18:53: CPU reset by debugger.
Sat Oct 19, 2013 12:18:53: Software reset was performed
Sat Oct 19, 2013 12:18:53: Target reset
Sat Oct 19, 2013 12:18:56: There was 1 warning during the initialization of the debugging session.
Sat Oct 19, 2013 12:18:56: Preset breakpoint encountered.
