hi,
i am entirely new to freescale semiconductor and i like to develop my knowledge in freescale. For that i choose to buy
Solved! Go to Solution.
Hi Parthiban kandasamy,
If you use FRDM-KL25Z, you don't need use other programmer, because the boad has the sophisticated OpenSDA Debug interface.
About detail, you can refer to the FRDM-KL25Z User's manual, the link is :
I wish it helps you!
Best regards!
Jing
Best regards!
Jing
thank you jingjing, its perfectly gave the answer which i need.just drag and drop application into bootloader then bootloader updates previous programmer am i right?
Yes, you are right. If you put the MSD-FRDM-KL25Z_Pemicro_v105.SDA into bootloader, you can send the xxx.srec to the bootloader, then the boader will run the according program.
and if you need debug, you should choose DEBUG-APP_Pemicro_v102.SDA into bootloader,then you can debug through the IDE(eg.CodeWarrior V10.x,IAR ARM Workbench or Keil MDK-ARM ).
You still can find detail information from openSDA user's guide ,the link is :
http://cache.freescale.com/files/32bit/doc/user_guide/OPENSDAUG.pdf?fpsp=1
Best regards!
Jing
