Support Two USB Disks through USB Hub in Android
shaojun_wang
1. In device/fsl/imx6/sabresd/vold.fstab, change
    dev_mount udisk /mnt/udisk auto /devices/platform/fsl-ehci.0/usb1
    to
    dev_mount udisk /mnt/udisk auto /devices/platform/fsl-ehci.0/usb1/1-1/1-1.4
    dev_mount udisk1 /mnt/udisk1 auto /devices/platform/fsl-ehci.0/usb1/1-1/1-1.1
    1-1 is usb hub device name in sysfs, 1-1.4 and 1-1.1 is usb hub port number in sysfs. You can get this number from kernel log when insert usb hub and usb disk.
2. In device/fsl/imx6/sabresd/overlay/frameworks/base/core/res/res/xml/storage_list.xm, add below code before </StorageList>.
    <storage android:mountPoint="/mnt/udisk1"
        android:storageDescription="@string/storage_usb"
        android:primary="false"
        android:removable="true" />
3. Apply below patch in device/fsl/imx6/etc/init.rc
    diff --git a/imx6/etc/init.rc b/imx6/etc/init.rc
    index b33b654..397b809
    --- a/imx6/etc/init.rc
    +++ b/imx6/etc/init.rc
    @@ -24,7 +24,7 @@ loglevel 3
         export LOOP_MOUNTPOINT /mnt/obb
         export SHM_MOUNTPOINT /mnt/shm
         export EXTERNAL_STORAGE /mnt/sdcard
    -    export SECONDARY_STORAGE /mnt/extsd:/mnt/udisk
    +   export SECONDARY_STORAGE /mnt/extsd:/mnt/udisk:/mnt/udisk1
         export BOOTCLASSPATH /system/framework/core.jar:/system/framework/core-junit.jar:/system/framework/bouncycastle.jar:/system/framework/ext.jar:/system/framework/framework.jar:/system/framework/
         export LIGHTSENSOR_PATH /sys/class/i2c-adapter/i2c-1/1-0044
     @@ -55,6 +55,8 @@ loglevel 3
         symlink /mnt/extsd /extsd
         mkdir /mnt/udisk 0000 system system
         symlink /mnt/udisk /udisk
    +   mkdir /mnt/udisk1 0000 system system
    +   symlink /mnt/udisk1 /udisk1
         mkdir /system
         mkdir /data 0771 system system
         mkdir /cache 0770 system cache
Tags (3)
