Where is documention regarding C libraries?
stanschultz
I'm new with Kintetis and Freescale.  Doing some work with the K60 tower.  It seems like there should be a document somewhere that describes C routines/functions that are in libraries.  I haven't been able to find much documenting them.
kerryzhou
Hi Stan Schultz,
    You are welcome, if your question is solved, please mark your question as solved!
    Thank you and best regards!
Jing
kerryzhou
Hi Stan Schultz,
      Yes, Freescale have two documents about your question.
    1, MSL C Reference Version 10
         This reference contains a description of the ANSI library and extended libraries bundled with Main Standard Library for C.
     The link is :http://cache.freescale.com/files/soft_dev_tools/doc/ref_manual/MSL_C_Reference.pdf?fsrch=1&sr=10
    2,  EWL C Reference Manual
      The CodeWarrior C and C++ compilers use the Embedded Warrior Library (EWL) for C to provide and extend the libraries documented in the ISO/IEC standards for C. EWL C also offers facilities described in the POSIX specification and some common application
      programming iwnterfaces (APIs) from UNIX operating systems.
      The link is:http://cache.freescale.com/files/soft_dev_tools/doc/ref_manual/CWEWLCREF.pdf?fsrch=1&sr=11
I wish it helps you!
Best regards!
Jing
stanschultz
Thank you. That was very helpful. -Stan
kerryzhou
Hi Stan Schultz,
Jing
