jojo rong
error play video via gstreamer with "mfw_isink" in IMX6QSD
Discussion created by jojo rong on Oct 9, 2013
Latest reply on Aug 26, 2015 by Andrea Picaro
I collect much more detail of this issue about for play video streaming with gstreamer with plugin "mfw_isink" in yocto branch dora,
* video pipe line
pipleline: appsrc is-live=true do-timestamp=true caps="image/jpeg, width=1920, height=800" name="appsrc" ! decodebin2 ! mfw_isink name="appsink" disp-width=1910 disp-height=795 axis-top=153 axis-left=5
set color key
MFW_GST_ISINK_PLUGIN 3.0.8 build on Oct  9 2013 10:34:59.
[INFO]  Product Info: i.MX6Q/D/S
vpudec versions
        plugin: 3.0.8
        wrapper: 1.0.38(VPUWRAPPER_ARM_LINUX Build on Oct  8 2013 18:01:07)
        vpulib: 5.4.15
        firmware: 2.3.10.40778
[INFO]  bitstreamMode 1, chromaInterleave 0, mapType 0, tiled2LinearEnable 0
hwbuf allocator zone(2306048) created
can not create threadmfw_gst_isink_setcaps:1489
VS0 created. in fmt[I420] win(0,0-1920,800:1920x800) out win(5,153-1915,948:1910x795)
set deinterlace mode 0
imx-ipuv3 imx-ipuv3.0: IPU Warning - IPU_INT_STAT_10 = 0x00080000
imx-ipuv3 imx-ipuv3.0: IPU Warning - IPU_INT_STAT_5 = 0x88800000
mxc_sdc_fb mxc_sdc_fb.0: timeout when waiting for flip irq
vss/mfw_gst_vss_common.c:1003 ioctl error, return -1
* build version
Build Configuration:
BB_VERSION        = "1.20.0"
BUILD_SYS         = "i686-linux"
NATIVELSBSTRING   = "Ubuntu-12.04"
TARGET_SYS        = "arm-poky-linux-gnueabi"
MACHINE           = "imx6qsabresd"
DISTRO            = "poky"
DISTRO_VERSION    = "1.5"
TUNE_FEATURES     = "armv7a vfp neon callconvention-hard cortexa9"
TARGET_FPU        = "vfp-neon"
meta
meta-yocto        = "(nobranch):4d8ab87d25ea6e59dc88375813ef88ee0ac813d0"
meta-oe           = "(nobranch):8aafddccb03f54923927e9d1c8c80223baf581de"
meta-fsl-arm      = "(nobranch):2076ae7530a7ed2aa40678502598e74b0f533def"
meta-fsl-arm-extra = "(nobranch):cc64dc7e894915e9be4e6ac34e01a4f5c123b7b4"
meta-fsl-demos    = "(nobranch):393b0119d513f9abf7b0570ab0d32b81583dedca"
* local.conf
DL_DIR = "${TOPDIR}/../../downloads"
*boot cmd
mmcargs=setenv bootargs console=${console},${baudrate} root=${mmcroot} video=mxcfb1:off video=mxcfb0:dev=hdmi,1920x1080M@60,if=RGB24 dmfc=3
*startup script
echo 2 > /proc/cpu/alignment
export VSALPHA=1
* relatived hints which i searched from FREESCALE imx community:
** i think about this issue is reported because of my operation on X server at the same time with gstreamer pipe line with "mfw_isink" as description of bellow thread
https://community.freescale.com/message/322666#322666
  For a more simple case,
  I use the "get-launch" to play video with X server:
  pipe line : gst-launch filesrc location=/var/volatile/transformers3-mjpeg.mp4 typefind=true ! aiurdemux ! vpudec ! mfw_isink disp-width=1910 disp-height=795 axis-top=153 axis-left=5
set color key
Setting pipeline to PAUSED ...
vpudec versions
        plugin: 3.0.8
        vpulib: 5.4.15
Pipeline is PREROLLING ...
Aiur: 3.0.8
Core: MPEG4PARSER_06.06.03  build on Jul  3 2013 01:47:47
  mime: video/quicktime; audio/x-m4a; application/x-3gp
  file: /usr/lib/imx-mm/parser/lib_mp4_parser_arm11_elinux.so.3.1
Content Info:
        URI:
              file:///var/volatile/transformers3-mjpeg.mp4
        Idx File:
              /home/root/.aiur/.var.volatile.transformers3-mjpeg.mp4.aidx
        Seekable  : Yes
        Size(byte): 356249742
Movie Info:
        Seekable  : Yes
        Live      : No
        Duration  : 0:02:27.883008000
        ReadMode  : File
        Track     : 2
Track 00 [video_000000] Enabled
        Duration: 0:02:27.872992000
        Language: eng
        Mime:
              image/jpeg, width=(int)1920, height=(int)800, framerate=(fraction)1199/50
Track 01 [audio_000000] Enabled
        Duration: 0:02:27.882000000
        Language: eng
        Mime:
              audio/mpeg, mpegversion=(int)4, channels=(int)2, rate=(int)48000, bitrate=(int)1
              24665, framed=(boolean)true, stream-format=(string)raw, codec_data=(buffer)11905
              6e500
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
hwbuf allocator zone(61440imx-ipuv3 imx-ipuv3.0: IDMAC12's EBA0 is not 8-byte aligned
0) created
imx-ipuv3 imx-ipuv3.0: IDMAC11's EBA0 is not 8-byte aligned
hwbuf allocator zone(614400) destroied.
hwbuf allocator zone(614400) created
the following WARNing is reported when you active the X server window, looks like menu of mouse right is active,
The screen is black about for 2 ~ 3 seconds when the one Warning is reported, and then restore normal display,
that is said Warning is reported once, black screen once
  After much more Warning later, the bellow Error is reported, the HDMI screen is black complete, display no signal i need to reset the system to restore
