After wake up from LLS, MQX function does not work.
Question asked by Daniel Chai on Oct 7, 2013
After the system wakes up from LLS using  LLWU PTD0,  it run the instruction after asm("WFI").
But after asm("WFI"), I use lwgpio_init function to initialize the gpio, but it does not work.
I have to reset the register through set the registers directly then I can use lwgpio_init function.
Any suggestion about this?
Thank you.
-Daniel
