Humberto Goncalves
CW6.0 MCU - S08DZ60 - Troubles in generating SCI interruptions
Discussion created by Humberto Goncalves on Jul 28, 2007
Latest reply on Apr 22, 2020 by 雪峰 董
    I'm a new user of CodeWarrior IDE, I'm developing firmware for HS08 CPU cores. I'm trying to generate a simple interrupt for a TX routine (Serial Comm. Interface). The interrupt was intended to be generated via TDRE request, but when I debug the prgm I get the message from Command line in the True-Time Simulator....[SCI Warning - DMARE/DMATE bits are not functional and will prevent interrupts.]. I've tried to look in the HCS08 manual, and noting, but in a deep search I've found out that these bits exist in the HC08 family, but not in the HCS08 family wich is pretty wierd to me. I'd like to get some help, please.
Humberto
Message Edited by Humberto on 2007-07-28 02:52 PM
Alban Edit: FSL Part Number must figure in Message Subject line.
Message Edited by Alban on 2007-07-31 10:43 AM
Alban Edit: MODIFIED FSL Part Number from Message Subject line.
Message Edited by Alban on 2007-08-01 08:36 AM
