Real-time Debugger SH8,variables freeze
abicash
I am unsure whether it is an issue of the code.
I have 2 timers, one in PWM and another in I/P capture mode
I have declared 3200 bytes of data in flash and this is a look up table for PWM sine generation.For this i have a freq = 16KHz
const uchar sin_table[] @0xE800 ={  //data}
Second i detect rising edges of an input frequency (50Hz) and try to align the PWM with these edges.
When i attach USBMULTILINK with my target and hit 'Debug' i get close results of what i expect but after a while, all the variables declared just stop updating and my PWM output waveform is lost.
Even if i remove debugger and run the code , same observation!
Is it related to stack overflow? (Stacksize = 0x50)
Please someone point out what could be wrong?
Best Regards
Tags (2)
