I discovered a difference in code generation for processorexpert SynchroMaster (SPI) component when I use 2 cpu clock configurations.
It's in function SendChar.
One cpu clock configuration OK:
byte SPIFLASH_SendChar(SPIFLASH_TComData Chr)
SPIFLASH_TComData TmpChr = OutBuffer; /* Save OutBuffer value */
if ((SerFlag & FULL_TX) != 0U) { /* Is last character send? */
return ERR_TXFULL; /* If no then return error */
if (EnUser) { /* Is device enabled? */
SMasterLdd1_Main(SMasterLdd1_DeviceDataPtr);
OutBuffer = Chr; /* Save character */
if (SMasterLdd1_SendBlock(SMasterLdd1_DeviceDataPtr, (LDD_TData *)&OutBuffer, 1U) == ERR_BUSY) { /* Send one data byte */
OutBuffer = TmpChr; /* If is device busy, restore OutBuffer value */
return ERR_TXFULL;
} else {
SerFlag |= FULL_TX; /* ...and set flag */
return ERR_OK;
Two cpu clock configurations ERROR
if (!EnMode) { /* Is the device disabled in the actual speed CPU mode? */
return ERR_SPEED; /* If yes then error */
return ERR_TXFULL;
SerFlag &= (byte)~(TX_BUF_EMPTY); /* Clear TX_BUF_EMPTY flag */
return ERR_OK;
I have tested this with few test projects and different toolchains in CW 10.4.
Any suggestions what should I try to get this solved?
thnx,b
Solved! Go to Solution.
I have just find out that issue was already fixed in CW V10.5.
Could you please to move to this version or you would like rather prefer hot-fix for CW V10.4?
Vojtech Filip
Processor Expert Support Team
I have reproduce it and I have classified it as bug in CW V10.4. The fix of this issue will be published in CW V10.6 (Q1-Q2 2014). For now as workaround is necessary to freeze generated code of this component. This feature is available after right click on the component, command Code Generation -> "Don´t Write ...."
Note: For future issue related to the Processor Expert please use corresponding forum: https://community.freescale.com/community/pex
In case the workaround would not be sufficient for you we will prepare hot-fix for this issue.
We are sorry for inconvenience.
Vojtech Filip
Screwed again. Seems like every time I find out the last 3 days were wasted because of a "bug" that is resolved by a CW version update, it costs our company $1600 to get the license file updated.
Vojtech Filip
I will go with 10.5
thank you for help!
