CodeWarrior USB TAP, Windows 7 and Flash Programmer
Question asked by Marianna Buschle on Sep 18, 2013
Latest reply on Oct 2, 2013 by Marianna Buschle
I have CodeWarrior 7.3 installed on a Windows 7 machine and was able to get the USB TAP up and running by following AN4338.
I have now tried to install the standalone Flash Programmer 1.2 because I need some batch scripts to write different Srec files to different memory areas in my board (a 56F8366).
During the installation it complained about the drivers.
When I try to run it it erases the Flash and then gives a "CCCSClient::WriteMemoryDirect: Core not responding" message.
Loading through CodeWarrior works fine.
I have tried substituting the ccs folder with the ccs folder from my CodeWarrior installation and still nothing.
I have also tried the ccs folder from this post: Problem with CodeWarrior USB TAP and Win 7.
Still the same...
Thank you
Marianna S. Buschle
