building u-boot iMX28EVK for NAND flash
francescoluccon
Hi guys,
I'm involved into a preliminary work for iMX28EVK board and I'm trying to build an u-boot bin file (cross-compiled from an vanilla project)
and installing it through mfg tool.
It seems that using the u-boot.sb (generated at the end of the building) and moving it into the right profile directory, the tool completes the u-boot
installation but resetting the board (just pressing the reset button) the boot-loader doesn't start up.
Have you experienced this problem? How have you solved it?
Thank you in advance, best regards.
Francesco
fabio_estevam
Please check section "3) Installation of U-Boot for a MXS based board to SD card" from:
http://git.denx.de/?p=u-boot.git;a=blob;f=doc/README.mxs;h=5d9e72f958d5ca8c7848d04f5c55e1f2b1f0feac;...
fabio_estevam
Sorry, I meant section "4) Installation of U-Boot into NAND flash on a MX28 based board"
