Looking at the vybrid data sheet, there are multiple channels for two ADC ports. But it appears that I can only take 2 measurements at a time. I would like to use the DMA to store samples in memory. If I only have one DMA channel available, I'm guessing that I can only take one measurement at a time. Is there a way to interleave data?
Solved! Go to Solution.
Hello John,
Below is reply from another Community thread:
"Vybrid has 2 ADCs. Each can be synchronized by External hardware trigger support.
If you raise each, for each ADC, with two separate triggers at the same time, 2 ADCs will measure at the same time. For example using Programmable Delay Block (PDB)."
It might be not exactly about what you are asking, but it gave me a hint that you may probably use the Programmable Delay Block (PDB) to interleave data as well, i.e. make the 2 ADCs' data flow through one DMA channel in the synchronized manner.
Sincerely, Naoum Gitnik.
Hello John,
