internal storage not mounted after factory reset on i.mx6 platform
lqw39
Hi, all,
We encountered a critical issue: internal storage cannot be mounted after factory reset.
Internal storage is correct after I download images via MFGTool, and mount info is:
rootfs / rootfs ro,relatime 0 0
tmpfs /dev tmpfs rw,nosuid,relatime,mode=755 0 0
devpts /dev/pts devpts rw,relatime,mode=600 0 0
proc /proc proc rw,relatime 0 0
sysfs /sys sysfs rw,relatime 0 0
none /acct cgroup rw,relatime,cpuacct 0 0
tmpfs /mnt/secure tmpfs rw,relatime,mode=700 0 0
tmpfs /mnt/asec tmpfs rw,relatime,mode=755,gid=1000 0 0
tmpfs /mnt/obb tmpfs rw,relatime,mode=755,gid=1000 0 0
tmpfs /mnt/shm tmpfs rw,relatime,size=1024k,mode=775,uid=1000,gid=1003 0 0
none /dev/cpuctl cgroup rw,relatime,cpu 0 0
/dev/block/mmcblk0p5 /system ext4 ro,relatime,user_xattr,acl,barrier=1,data=ordered 0 0
/dev/block/mmcblk0p4 /data ext4 rw,nosuid,nodev,noatime,nodiratime,errors=panic,user_xattr,acl,barrier=1,nomblk_io_submit,data=ordered,noauto_da_alloc 0 0
/dev/block/mmcblk0p6 /cache ext4 rw,nosuid,nodev,relatime,user_xattr,acl,barrier=1,nomblk_io_submit,data=ordered 0 0
/dev/block/mmcblk0p7 /device ext4 ro,relatime,user_xattr,acl,barrier=1,data=ordered 0 0
/dev/block/mmcblk0p8 /vendor ext4 rw,nosuid,nodev,relatime,user_xattr,acl,barrier=1,data=ordered 0 0
none /sys/kernel/debug debugfs rw,relatime 0 0
/dev/fuse /mnt/shell/emulated fuse rw,nosuid,nodev,relatime,user_id=1023,group_id=1023,default_permissions,allow_other 0 0
/dev/block/vold/179:25 /mnt/extsd vfat rw,dirsync,nosuid,nodev,noexec,relatime,uid=1000,gid=1023,fmask=0002,dmask=0002,allow_utime=0020,codepage=cp437,iocharset=iso8859-1,shortname=mixed,utf8,errors=remount-ro 0 0
But internal storage cannot be mounted after factory reset, the mount info is:
/dev/block/mmcblk0p7 /device ext4 ro,nosuid,nodev,relatime,user_xattr,acl,barrier=1,data=ordered 0 0
There is no /dev/fuse.
Anyone can help me?
Thanks.
Labels (2)
YixingKong
Senior Contributor IV
Qingwei
This discussion is closed since no activity. If you still need help, please feel free to reply with an update to this discussion, or create another discussion.
Yixing
YixingKong
Qingwei
Had your issue got resolved? If yes, we are going to close the discussion in 3 days. If you still need help, please feel free to reply with an update to this discussion.
Yixing
raymondwang
You'd better paste your logcat log to capture error.
