Qt debugging on yocto I (running on sabrelite)
Question asked by Diego Gonzalez on Sep 5, 2013
Latest reply on Sep 9, 2013 by Diego Gonzalez /Jose Ferreiro
Hello everyone!
I'm writing here to expose a question about QT debugging on yocto using sabreliteimx6 .I can run perfectly my application on my board using yocto (dylan). However when I try to debug my application and add an expression evaluator
( I want to see a variable value) the compiler logs tells me :
<484bb options:fancy,autoderef,dyntype vars:watch.4 expanded:return,local,watch,inspect typeformats: formats: watchers:772377617463682e332323692377617463682e3223236a2377617463682e3323236a3d332377617463682e312323612377617463682e34
>&"bb options:fancy,autoderef,dyntype vars:watch.4 expanded:return,local,watch,inspect typeformats: formats: watchers:772377617463682e332323692377617463682e3223236a2377617463682e3323236a3d332377617463682e312323612377617463682e34\n"
>&"Undefined command: \"bb\". Try \"help\".\n"
>484^error,msg="Undefined command: \"bb\". Try \"help\"."
dDUMPER FAILED: 484^error,data={msg="Undefined command: \"bb\". Try \"help\"."}
As you can see the GDB don't recognize bb so if I type the command help
<485help
>&"help\n"
>~"List of classes of commands:\n\n"
>~"aliases -- Aliases of other commands\n"
>~"breakpoints -- Making program stop at certain points\n"
>~"data -- Examining data\n"
>~"files -- Specifying and examining files\n"
>~"internals -- Maintenance commands\n"
>~"obscure -- Obscure features\n"
>~"running -- Running the program\n"
>~"stack -- Examining the stack\n"
>~"status -- Status inquiries\n"
>~"support -- Support facilities\n"
>~"tracepoints -- Tracing of program execution without stopping the program\n"
>~"user-defined -- User-defined commands\n"
>~"\nType \"help\" followed by a class name for a list of commands in "
>~"that class.\nType \"help all\" for the list of all commands."
>~"\nType \"help\" followed by command name "
>~"for full documentation.\n"
>~"Type \"apropos word\" to search for commands related to \"word\".\n"
>~"Command name abbreviations are allowed if unambiguous.\n"
>485^done
I don't see bb command.
Any idea how to fix it? Does anyone else have the same problem?
Thank you!
Diego.
