MVF61NSxx/about ethernet phy of Vybrid
soichiyamamoto
Contributor V
I have question about ethernet phy of MVF61NSxx.
KSZ8041NL is not available.(EOL)
A PHY driver software of Linux wants you to introduce available ethernet PHY.
As for the KSZ8081 series, is a driver software of Linux available?
Soichi yamamoto,
MehmetAliIpin
Contributor V
Dear Soichi,
You can find Linux driver here: http://www.micrel.com/_PDF/?dir=Ethernet/sw_designkit/PHY_Products/KSZ8081/Device_Drivers
Mehmet Ali Ipin
naoumgitnik
Senior Contributor V
Dear Soichi,
I am a hardware person but will try to help you.
If our existing driver only handles the IEEE-standard PHY's configuration registers, then it is not PHY-specific.
May you comment on that, please?
Regards, Naoum Gitnik.
