Error compiling gst-plugins-good
Question asked by Javier Valcarce on Sep 3, 2013
Latest reply on Feb 25, 2014 by Yixing Kong
Hi all.
I'm trying to compile gst-plugins-good package but i get the following error.
cairo_overlay.c:27:19: fatal error: cairo.h: No such file or directory
Can anyone help me?
I have read gst-fsl-plugins build failed
I have tried to comment "export lines" at *.spec file but the result is the same.
make -C v4l2
make -C cairo
make[4]: Entering directory `/home/javier/ltib/rpm/BUILD/gst-plugins-good-0.10.30/tests/examples/rtp'
make[4]: Entering directory `/home/javier/ltib/rpm/BUILD/gst-plugins-good-0.10.30/tests/examples/cairo'
  CC     cairo_overlay-cairo_overlay.o
make[4]: Nothing to be done for `all'.
make[4]: Leaving directory `/home/javier/ltib/rpm/BUILD/gst-plugins-good-0.10.30/tests/examples/rtp'
make[4]: Entering directory `/home/javier/ltib/rpm/BUILD/gst-plugins-good-0.10.30/tests/examples/shapewipe'
make[4]: Leaving directory `/home/javier/ltib/rpm/BUILD/gst-plugins-good-0.10.30/tests/examples/shapewipe'
make[4]: Entering directory `/home/javier/ltib/rpm/BUILD/gst-plugins-good-0.10.30/tests/examples/equalizer'
make[4]: Leaving directory `/home/javier/ltib/rpm/BUILD/gst-plugins-good-0.10.30/tests/examples/equalizer'
make[4]: Entering directory `/home/javier/ltib/rpm/BUILD/gst-plugins-good-0.10.30/tests/examples/v4l2'
make[4]: Leaving directory `/home/javier/ltib/rpm/BUILD/gst-plugins-good-0.10.30/tests/examples/v4l2'
make[4]: Entering directory `/home/javier/ltib/rpm/BUILD/gst-plugins-good-0.10.30/tests/examples/spectrum'
make[4]: Leaving directory `/home/javier/ltib/rpm/BUILD/gst-plugins-good-0.10.30/tests/examples/spectrum'
compilation terminated.
make[4]: *** [cairo_overlay-cairo_overlay.o] Error 1
make[4]: Leaving directory `/home/javier/ltib/rpm/BUILD/gst-plugins-good-0.10.30/tests/examples/cairo'
make[3]: *** [cairo] Error 2
make[3]: Leaving directory `/home/javier/ltib/rpm/BUILD/gst-plugins-good-0.10.30/tests/examples'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/home/javier/ltib/rpm/BUILD/gst-plugins-good-0.10.30/tests'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/javier/ltib/rpm/BUILD/gst-plugins-good-0.10.30'
make: *** [all] Error 2
error: Bad exit status from /home/javier/ltib/tmp/rpm-tmp.47999 (%build)
RPM build errors:
Build time for gst-plugins-good: 19 seconds
Failed building gst-plugins-good
f_buildrpms() returned an error, exiting
traceback:
main:572
Started: Tue Sep  3 17:00:13 2013
Ended:   Tue Sep  3 17:00:35 2013
Elapsed: 22 seconds
These packages failed to build:
gst-plugins-good
Build Failed
Exiting on error or interrupt
