I'm working on implementing SPI for the VF65GS10 and need to implement both master and slave modes. I'd prefer to use the SPI driver in MQX 4.0.2 if possible, but I'm not sure if it supports both modes. The release notes seem to say that it only supports master mode, but the MQX IO User Guide appears to state the contrary. Which is correct?
Thanks much.
SPI slave operation not supported in MQX 4.0.1
