Power consumption estimation
niuweiqiang
Dear i.mx6 developer:
I am going to use i.mx6S processor.
But, I find a question during power consumption with the help of "iMX6X_Power_Tree_5Vin_separate" tool.
It is found that the parameter in line 17 impact the total power consumption greatly.
I can't confirm which value is suitable.
Can you give the advice or guide me confirm the actual value?
Thank you very much
Best regards.
jamesbone
Can you please share with us the file that you are refering ?.   You can check the application note
http://cache.freescale.com/files/32bit/doc/app_note/AN4715.pdf
This would provide Power Consumption Measurement numbers.
niuweiqiang
Hi Jamebone:
Thank you very much for your support.
I have checked the application Notes.
I find that the default resistor value is 120 ohm.
Please review below document in Line 17.
When the terminal resistor value is changed. The total power consumption
will be impacted.
Thank you very much
Best regards.
WeiQiang Niu
ABB Engineering (Shanghai)Ltd
No.5,lane 369,Chuangye Road,
Kangqiao Town,Pudong District,201319
Shanghai P.R.China
Phone: +86(21)6129 8121
Telefax: +86(21)6105 6905
Mobile: +86 1366 183 9086
email: weiqiang.niu@cn.abb.com
YixingKong
Senior Contributor IV
Weiqiang
This discussion is closed since no activity. If you still need help, please feel free to reply with an update to this discussion, or create another discussion.
Yixing
YixingKong
Weiqiang
Had your issue got resolved? If yes, we are going to close the discussion in 3 days. If you still need help, please feel
free to reply with an update to this discussion.
Yixing
