Simbu
Corenet fabric speed
Discussion created by Simbu on Aug 22, 2013
Latest reply on Aug 26, 2013 by Simbu
Hi All,
In past, I think the FSB (Front Side Bus/Bus Speed) for any processor is computed against half the clock rate, so for e.g. 1.8 GHz processor with dual 32 Bit bus , both clocked at 450 Mhz. If I use the same concept here(p4080 -1.5 Ghz) in case of fabric and assume the fabric is accelerated @ ~750 Mhz .
Is this assumption right? It would be great, if someone can clarify how can we correlate the bus speed against fabric speed?
Any specific document or reference link will also be helpful..
Thanks in Advance.
