CodeWarrior 10.4 Evaluation Installation Issues
thoomanwang
Contributor V
I downloaded the CodeWarrior 10.4 Evaluation , also applied for a license, but after I installed license management interface appears in the following interface
Try a bit and found a 64K code limit , how should I do to trial Professional Edition features it ?
Tags (2)
ZhangJennie
please check your license install path. it must be under path {CW10 install}\MCU
ZhangJennie
thoomanwang
Contributor V
THanks
