MQX Lite Problem
Question asked by pk2 on Aug 20, 2013
I am trying to use MQX Lite on a K52 and am having a problem with a simple application.  I created a MQX Lite project for a K52 and did nothing other than generate the PE files and build the project.  When I debug the debugger stops here:
PE_ISR(Cpu_ivINT_Hard_Fault)
  /* This code can be changed using the CPU component property "Build Options / Unhandled int code" */
  PE_DEBUGHALT();
Any ideas why this happens?
Files attached (Archive of the project)
Original Attachment has been moved to: test03.zip
