Working on a PCB board blank drawing and need a 3D model for the MPXAZ6115AP pressure sensor. This sensor uses the package CASE1369 as specified on the data sheet. This is the right angle package with the barb connection.
You may find the 3D model in STEP format in Sensors Documents.
