- Which CPU are you targeting (HC08, HC12, Coldfire, ..)HCS08
- Which version of CodeWarrior are you using?
5.7.0.
5.9.0.
I've just got a CW Special Edition (version 5.7.0) with a softec Evaluation Board. I installed the software and ran the updater, nothing more. After launching CW, it crashes when I try to simply create/open a project. The window just "disapears" with no error messages or anything else.
I downloaded the last version (5.9.0.) on the freescale website and I installed it on antoher computer. Same as above, I ran the updater and nothing more, and I have the same problem.
When I click on "open" or "set.." in the create project menu or "open workspace" or "load example" the software crahses and I have to relaunch it.
Thanks for any help ...
