about the sabresd platform touch sensor
erichu
Is there any one knows about the touch sensor used on the sabresd platform board. how much touch point actually support by the hardware?
YixingKong
Senior Contributor IV
Eric
This discussion is closed since no activity. If you still need help, please feel free to reply with an update to this discussion, or create another discussion.
Yixing
4guin4g4
You may need to contact the display vendor in order to get more information about what is their panel capable of accomplishing.
You can also review the source code <ltib_dir>/rpm/BUILD/linux/drivers/video/mxc/ldb.c
erichu
I am talking about the freescale sabresd platform, it comes with that lcd panel. Also, wont be able to find any documentation which covers that chipset. I did a driver debugging, it shows only 2 points support. Can you confirm that? I have seen another post from some freescale people said that it only depend on software.
YixingKong
Eric
Had your issue got resolved? If yes, we are going to close the discussion in 3 days. If you still need help, please feel free to reply with an update to this discussion.
Yixing
