Python on Kinetis?
Python on Kinetis?
bfac
Following up with a recent question from a customer,
Have you heard any words on support for python programming on Kinetis?
Or maybe other higher level programming language?
Thanks!
Bruno
Tags (2)
bobpaddock
Senior Contributor III
Lua is an easy language to embedded in resource limited micros.
The Programming Language Lua
eLua - eluaproject
In the past I set up a project where non-computer people were writing simple scripts to handle sensor scaling.
The customer always changed the sensors in the field and there was no way to know in advance how to scale data.
They didn't even realize they where using a computer language to get the job done.
Squirrel - The Programming Language
is a combination of Python and Lua.  Core code takes about 8K of C.
I have not yet personally used it so, don't know how easy it is to embedded in a small micro.
There is also CPython - Wikipedia, the free encyclopedia , that you probably already know about.
kai_liu
Great to know these projects. And it takes time to evaluate them.
kai_liu
This is an interesting idea.
The Owl Embedded Python System
offers an open source embedded Python on TI MCU.
Maybe you can consider it as an idea of Kinetis to bring more attention and run it as your own project.
Yours sincerely
Allan K Liu
