HC12 mcu ERROR illegal redefinition of label
Question asked by Andrew Ramos on Aug 13, 2013
Latest reply on Aug 14, 2013 by Andrew Ramos
ADD_OP               EQU         $11
SUB_OP               EQU         $22
MUL_OP               EQU         $33
CLR_OP               EQU         $44
END_OP               EQU         $55
PROG_START      EQU          $1100
OUTPUT                EQU         $1050
                ORG         $1000
                FCB         $45,$11,$54,$33,$37,$22,$31,$44,$04,$33,$02,$11,$F9,$55
                ORG    PROG_START                                          ;program is written to memory location
                LDX         #$1000
                LDY         #$1001
                STX          $2020
                STY           $2022
                LDX           #$1050
                STX            $2015
                 LDX           #$01
                STX            $2013
LOOP       LDAA        #$00                              ;reset the ccr to test loop counter value
                TAP
                TST            $2013                              ;test counter memory location to change the operand 1's location
                BNE           LOOPTWO
                MOVW        $2015,$2020                 ; to change the operand 1 location with in memory
LOOPTWO         DEC    $2013                      ;to decrement value of the counter for the loops
                          LDX    $2020
                          LDY    $2022
                          LDAA        1,X+                          ;to load the oprand1
                          STX    $2020
                          LDAB    2,Y+                      ;to load the operation / oprand2
                         STY    $2022
                         CMPB        #$44                       ;clear test
                         BNE         SUB_CHK
                         JMP         CLR_OP
SUB_CHK         CMPB        #$22                    ;subtraction test
                         BNE         ADD_CHK
                        JMP         SUB_OP
ADD_CHK         CMPB        #$11                       ;addition test
                        BNE         MUL_CHK
                         JMP         ADD_OP
MUL_CHK         CMPB        #$33                          ;multiplication test
                         BNE         END_CHK
                         JMP         MUL_OP
END_CHK         CMPB        #$55                          ;end test
                        BNE         FINAL
CLR_OP          LDAB    -1,Y                                   ;op clear                                   //Here is where i get the error A1103 Illegal redefinition of label
                       TBA
                       LDAB    #$00
                       STAB    OUTPUT
                      JMP         LOOP
SUB_OP          LDAB    -1,Y                                   ;op subtract                              //Also here the same error
                       SBA
                       JMP         TEST
// I have no idea what the error is i try to move the labels around i have 3 columns for the (labels,op code, oprand). Please any help would be appreciated.
Thank you
