KL02  SWD_DIO or SWD_CLK
Question asked by Patrick Irwin on Aug 9, 2013
Latest reply on Aug 19, 2013 by Patrick Irwin
We are currently using MKL02Z16VFG4 (16 pin device) in a new
design.  In this design we are using all
of the pins except for pin 16 (PTA2/SWD_DIO) and pin 14 (PTA0/SWD_CLK).  After programming, we need to use one of
these pins to drive an N-Channel MOSFET, which is being used as a switch.  The N-Channel MOSFET has a pull down 10K ohm
resistor from its gate to ground.
Which pin should we be using?
Pat
