I'm here again because I'm improving some code donde before and I'm trying to make it easy to read, I'm trying to make it more "friendly".... My question is: Is there any way to use the same labels (macro declarations) in C and Assembler?
What I was doing before was:
in ASM: pin_1 equ $04 port_! equ PORTA
in C: #define PIN_1 $04 #define PORT_1 PORTA
So I was refering to the same pin both in C and ASM, and to distinguish C from ASM I use UPPER CASE for C and lower case for ASM....
I hope you could help me with that....
So I can define in C: #define pin_1 $04 #define port_1 PORTA
The compiler supports to generate assembly include files with the content of a C header file, check in the compiler heade file the chapter Generating Assembler Include Files (-La compiler option) Daniel
