I am working on a design that requires an RMII Ethernet interface and two I2C interfaces (one master and 1 slave). Will the MK60FN1M0VLQ12 support this? WIll the MDIO / MDC interface (pins 81 and 82 for this device) and both I2C0 and I2C1 work at the same time (i.e. simultaneously)?
Hi, PK2
No, you can use I2C and RMII at the same time. I suggest you use Pin 137,138 for I2C0.
Hope my reply can help you.
Best Regards
Paul
Is there a reason I can not use pins 83 and 84?
Hi, PK2
Yes, you can use pin 83 and 84.
