Dear support,
Is the fuse of Vybrid evaluation board already blown?
(In case it is, please let us know the status of it.)
We'd like to use it to test the boot mode.
Keisuke
Solved! Go to Solution.
No, there are no boot fuses blown on the tower board. It uses the jumpers on J22 to select the boot interface.
Note that once you blow the fuses, it is a permanent change.
