How to use the multiplexed configuration pins
Question asked by nishad kamdar on Jul 29, 2013
Latest reply on Aug 1, 2013 by lunminliang
As mentioned in the P1022RM, the configuration pins are multiplexed with some of the bidirectional pins.
In case one of interfaces connected to these pins needs a pull up resistor, for instance (WE# of the NAND Flash (LFALE)) and I need to input a 0 to the config pin of the processor for a particular configuration, how can I achieve this (without an FPGA or a CPLD) as I cannot connect a pull up and a pull down on the same pin/connection.
Kindly help me in this regard,
