mx53 QSB run our own image file problem
Question asked by swapneel sangar on Jul 21, 2013
  HIiiii
I try to create our own image file. For this I install LTib as per the given procedure in mx53 start linux bsp userguide.pdf. After that follow the command given in section 7 to laod the file in micoSD card. After that follow the command given in section 8.2 to run the image from SD. But it show only penguin on VGA display and show freescale login message on serial terminal. When I give root as log in id then it ask for command. Also before that it show message
EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
cp: write error: No space left on device
I use 8 GB memory card then why it show this space error?  How I can remove this problem?  I attachment here hyper terminal text file.
Please find this attachment..........
Thank you
swapneel
Original Attachment has been moved to: hyper.txt.zip
