Kevin Ma
MSC8122  - different compiler optimization levels, intrinsics
Discussion created by Kevin Ma on Jul 18, 2007
Latest reply on Jul 18, 2007 by CrasyCat
I'm optimizing a project for Starcore MSC8122 with CW v5.7.0 (build 2262) in Windows XP. In my project I found issues that,
(1) (Without using any intrinsics) when compiling with O1, O2 or O3, results are wrong;
(2) Without intrinsics some modules/functions are ok with O3, but when using "norm_l" intrinsic, result at O0 is ok but at O1/O3 is wrong. Debugging revealed at least one problem: at one place the compiler was getting the value for a variable from a wrong place (pointed by stack pointer SP + wrong offset).
I understand (1) somewhat, although it's hardly acceptable. For (2), what can be the reason? Is it because my code is all in integer mode? norm_l is supposed to give same result for intergers or fractionals, since no shifting or saturation is involved, right?
Thanks.
Kevin
Added part number to subject.
Message Edited by NLFSJ on 2007-07-17 06:42 PM
