Would you have a plan to provide any circuit review documents?
Hiroki
Solved! Go to Solution.
Dear Hiroki,
Thanks for referring me to the document. Now I understand what you mean, although first I thought you meant a special document describing how to treat the unused pins.
We are planning something similar to that App. Note but we call it "Design Guide"; meanwhile, please, use the relevant information from the Datasheet, Reference Manual, and Reference Platform schematic.
Sincerely, Naoum Gitnik.
Hi Naoum,
I'd like to know each pins' treatment of Vybrid, for example PTA0 needs a pull-up. Some customers require FSL to review their board. And I need a document of the reference for a circuit review of Vybrid.
Hiroki
Dear Hiroki,
It is clear now.
Hi Naoum,
I want a design check list like QorIQ.
I'd like to know non used pins' treatments.
Hiroki
Dear Hiroki,
May you refer to that specific document, please?
Hi Naoum,
Does that specific document mean the board schematic and the datasheet?
Hiroki
Dear Hiroki,
I meant the "design check list like QorIQ" you referred me to - unfortunately, I am not familiar with it.
Hi Naoum,
This is the design checklist URL.
I'd like FSL to prepare the document like this for Vybrid, too.
Hiroki
Dear Hiroki,
Dear Naoum,
When this design guide will be available?
Thanks and best regards
Dear Hiroki,
May you be a little more specific, please? - Any examples of the "circuit review documents" mentioned, please?
