DHCP not functional on Linux?
Question asked by rizwan on Jul 17, 2013
Latest reply on Aug 30, 2013 by Timesys Support
Folks,
We are booting  Linux (uImage-3.0-ts-armv7l)  on Vybrid from SD card, but DHCP assignment does not work properly in the Linux and we are getting the following errors:
“DHCP/BOOTP : Reply not for us, op[2] xid[b7926695]”
We are using following Jumper settings on Tower Serial (TWR-SER) module:
J2 – Ethernet PHY Clock Select – 3-4 closed (50MHz)
J3 – CLOCKIN0 Driver Select  – 2-3 closed (Route 50MHz clock to CLOCKIN0)
J12 – Ethernet PHY Configuration– 9-10 closed (RMII Select)
Kindly help us sort out this issue or there is anything missing in the Jumper settings we are using on TWR-VF65GS10 and TWR-SER module.
Rizwan Rasheed
