What is the probability of is using a USB Tap && utilizing Cross-triggering && using a P5040/21 via CW for Power Architectures (non-automotive/MCU version)? Need a rough order magnitude type of indicator… (Never, often, everyday)
Solved! Go to Solution.
Hi Robert,
As far I know, I don't think this scenario is very used. Btw, the cross triggering works for P5040/21DS, but for P5040/21RDB (that will be provided in the next PA SP) is not working (due of CR:ENGR00268643 that cannot be integrated via SP).
Marius
Hi Robert,
Marius
Not quite understand the question?
