When I Patch Code for i.MX , I get strange result
quandguo
I do this patch according to the Android_User_Guide.pdf
pwd
cd /ext/myandroid_r13
pwd
source /ext/android_bak/r13/imx-android-13.4.1/code/13.4.1/and_patch.sh
help
c_patch /ext/android_bak/r13/imx-android-13.4.1/code/13.4.1 imx_13.4.1
cd /host/myandroid
curl https://dl-ssl.google.com/dl/googlesource/git-repo/repo > ./repo
chmod a+x ./repo
./repo init -u https://android.googlesource.com/platform/manifest -b android-4.0.4_r1.1
cp /home/hkbdm/r13/imx-android-13.4.1/code/13.4.1/default.xml .repo/manifests/default.xml
./repo sync -f
the result:
/ext/myandroid_r13/hardware/imx/.git/rebase-apply/patch:4759: new blank line at EOF.
warning: 2 lines add whitespace errors.
/ext/myandroid_r13/hardware/imx/.git/rebase-apply/patch:261: new blank line at EOF.
warning: 1 line adds whitespace errors.
/ext/myandroid_r13/hardware/imx/.git/rebase-apply/patch:92: trailing whitespace.
/ext/myandroid_r13/hardware/imx/.git/rebase-apply/patch:128: trailing whitespace.
/ext/myandroid_r13/hardware/imx/.git/rebase-apply/patch:139: trailing whitespace.
/ext/myandroid_r13/hardware/imx/.git/rebase-apply/patch:248: new blank line at EOF.
/ext/myandroid_r13/hardware/imx/.git/rebase-apply/patch:33: trailing whitespace.
/ext/myandroid_r13/hardware/imx/.git/rebase-apply/patch:117: trailing whitespace.
/ext/myandroid_r13/hardware/imx/.git/rebase-apply/patch:19: new blank line at EOF.
/ext/myandroid_r13/hardware/imx/.git/rebase-apply/patch:51: trailing whitespace.
/ext/myandroid_r13/hardware/imx/.git/rebase-apply/patch:127: trailing whitespace.
/ext/myandroid_r13/hardware/imx/.git/rebase-apply/patch:238: trailing whitespace.
/ext/myandroid_r13/hardware/imx/.git/rebase-apply/patch:283: trailing whitespace.
warning: 3 lines add whitespace errors.
/ext/myandroid_r13/hardware/imx/.git/rebase-apply/patch:2903: trailing whitespace.
    return devices;
/ext/myandroid_r13/hardware/imx/.git/rebase-apply/patch:3023: new blank line at EOF.
/ext/myandroid_r13/hardware/imx/.git/rebase-apply/patch:519: trailing whitespace.
            CAMERA_LOG_ERR("native_window_set_buffers_geometry failed:%s(%d)",
/ext/myandroid_r13/hardware/imx/.git/rebase-apply/patch:1985: trailing whitespace.
#define CAMERA_LOG_RUNTIME(format, ...)
/ext/myandroid_r13/hardware/imx/.git/rebase-apply/patch:2507: trailing whitespace.
        CAPTURE_DEVICE_RET ret = CAPTURE_DEVICE_ERR_NONE;
/ext/myandroid_r13/hardware/imx/.git/rebase-apply/patch:2549: trailing whitespace.
/ext/myandroid_r13/hardware/imx/.git/rebase-apply/patch:2757: trailing whitespace.
warning: squelched 8 whitespace errors
warning: 13 lines add whitespace errors.
/ext/myandroid_r13/hardware/imx/.git/rebase-apply/patch:103: trailing whitespace.
                        CAMERA_LOG_RUNTIME("dev_node: %s, sensor name: %s",
/ext/myandroid_r13/hardware/imx/.git/rebase-apply/patch:22: trailing whitespace.
        err = mNativeWindow->set_usage(mNativeWindow,
/ext/myandroid_r13/hardware/imx/.git/rebase-apply/patch:2288: new blank line at EOF.
/ext/myandroid_r13/hardware/imx/.git/rebase-apply/patch:515: trailing whitespace.
        //set mDoCsc
/ext/myandroid_r13/hardware/imx/.git/rebase-apply/patch:616: trailing whitespace.
    //stores nedd csc format.
/ext/myandroid_r13/hardware/imx/.git/rebase-apply/patch:69: trailing whitespace.
    .supported_devices   = AUDIO_DEVICE_OUT_ANLG_DOCK_HEADSET | AUDIO_DEVICE_OUT_DGTL_DOCK_HEADSET |
/ext/myandroid_r13/hardware/imx/.git/rebase-apply/patch:200: trailing whitespace.
Applying patch to hardware/ril
/ext/myandroid_r13/hardware/ril/.git/rebase-apply/patch:76: trailing whitespace.
// flag for pppd status. 1: started; 0: stoped
/ext/myandroid_r13/hardware/ril/.git/rebase-apply/patch:175: trailing whitespace.
  // Should already get local IP address from PPP link after IPCP negotation
/ext/myandroid_r13/hardware/ril/.git/rebase-apply/patch:176: trailing whitespace.
  // system property net.ppp0.local-ip is created by PPPD in "ip-up" script
/ext/myandroid_r13/hardware/ril/.git/rebase-apply/patch:185: trailing whitespace.
     response[2] = local_ip;
/ext/myandroid_r13/hardware/ril/.git/rebase-apply/patch:187: trailing whitespace.
     break;
warning: squelched 1 whitespace error
warning: 6 lines add whitespace errors.
/ext/myandroid_r13/hardware/ril/.git/rebase-apply/patch:41: trailing whitespace.
        /* Some HUAWEI USB datacards (e.g. E180) bootup and attach to network a little bit slowly(e.g. 20s).
/ext/myandroid_r13/hardware/ril/.git/rebase-apply/patch:53: trailing whitespace.
        LOGD ("Will delay RIL initialization for %d seconds", TIMEVAL_DELAYINIT.tv_sec);
/ext/myandroid_r13/hardware/ril/.git/rebase-apply/patch:655: new blank line at EOF.
/ext/myandroid_r13/hardware/ril/.git/rebase-apply/patch:17: trailing whitespace.
/ext/myandroid_r13/hardware/ril/.git/rebase-apply/patch:102: trailing whitespace.
            //Make a lock of s_commandmutex for different thread access for
/ext/myandroid_r13/hardware/ril/.git/rebase-apply/patch:111: trailing whitespace.
/ext/myandroid_r13/hardware/ril/.git/rebase-apply/patch:25: trailing whitespace.
/ext/myandroid_r13/hardware/ril/.git/rebase-apply/patch:101: trailing whitespace.
/ext/myandroid_r13/hardware/ril/.git/rebase-apply/patch:113: trailing whitespace.
/ext/myandroid_r13/hardware/ril/.git/rebase-apply/patch:147: trailing whitespace.
    //Need recover after read
/ext/myandroid_r13/hardware/ril/.git/rebase-apply/patch:204: trailing whitespace.
/ext/myandroid_r13/hardware/ril/.git/rebase-apply/patch:27: trailing whitespace.
/ext/myandroid_r13/hardware/ril/.git/rebase-apply/patch:33: trailing whitespace.
/ext/myandroid_r13/hardware/ril/.git/rebase-apply/patch:478: space before tab in indent.
  err = at_tok_nextstr(&line, &dir);
/ext/myandroid_r13/hardware/ril/.git/rebase-apply/patch:126: trailing whitespace.
/ext/myandroid_r13/hardware/ril/.git/rebase-apply/patch:135: trailing whitespace.
/ext/myandroid_r13/hardware/ril/.git/rebase-apply/patch:190: trailing whitespace.
/ext/myandroid_r13/hardware/ril/.git/rebase-apply/patch:650: trailing whitespace.
/ext/myandroid_r13/hardware/ril/.git/rebase-apply/patch:654: trailing whitespace.
warning: squelched 3 whitespace errors
warning: 8 lines add whitespace errors.
/ext/myandroid_r13/hardware/ril/.git/rebase-apply/patch:1262: new blank line at EOF.
Applying patch to libcore
Applying patch to packages/apps/fsl_imx_demo
/ext/myandroid_r13/packages/apps/fsl_imx_demo/.git/rebase-apply/patch:12: trailing whitespace.
It  is not only for E-Ink app, but also some other app we have done for demo usage.
/ext/myandroid_r13/packages/apps/fsl_imx_demo/.git/rebase-apply/patch:95: trailing whitespace.
/ext/myandroid_r13/packages/apps/fsl_imx_demo/.git/rebase-apply/patch:96: trailing whitespace.
/ext/myandroid_r13/packages/apps/fsl_imx_demo/.git/rebase-apply/patch:529: trailing whitespace.
/ext/myandroid_r13/packages/apps/fsl_imx_demo/.git/rebase-apply/patch:533: space before tab in indent.
    mContext = context;
/ext/myandroid_r13/packages/apps/fsl_imx_demo/.git/rebase-apply/patch:539: space before tab in indent.
    mContext = context;
warning: squelched 159 whitespace errors
warning: 164 lines add whitespace errors.
Applying patch to packages/apps/Browser
Applying patch to packages/apps/Camera
Applying patch to packages/apps/Gallery
Applying patch to packages/apps/Gallery2
Applying patch to packages/apps/Launcher2
Applying patch to packages/apps/Music
Applying patch to packages/apps/Settings
/ext/myandroid_r13/packages/apps/Settings/.git/rebase-apply/patch:83: trailing whitespace.
    </string-array>
/ext/myandroid_r13/packages/apps/Settings/.git/rebase-apply/patch:99: trailing whitespace.
    </string-array>
/ext/myandroid_r13/packages/apps/Settings/.git/rebase-apply/patch:115: trailing whitespace.
    </string-array>
/ext/myandroid_r13/packages/apps/Settings/.git/rebase-apply/patch:131: trailing whitespace.
    </string-array>
/ext/myandroid_r13/packages/apps/Settings/.git/rebase-apply/patch:132: trailing whitespace.
warning: squelched 79 whitespace errors
warning: 84 lines add whitespace errors.
/ext/myandroid_r13/packages/apps/Settings/.git/rebase-apply/patch:30: trailing whitespace.
    </string-array>
/ext/myandroid_r13/packages/apps/Settings/.git/rebase-apply/patch:270: trailing whitespace.
    private static final int MAX_DISPLAY_DEVICE = 6;
/ext/myandroid_r13/packages/apps/Settings/.git/rebase-apply/patch:642: trailing whitespace.
                updateDisplayColorDepthPreferenceDescription(dispid, currentDisplayColorDepth);
/ext/myandroid_r13/packages/apps/Settings/.git/rebase-apply/patch:130: trailing whitespace.
                int value = Integer.parseInt(objValue.toString());
/ext/myandroid_r13/packages/apps/Settings/.git/rebase-apply/patch:160: trailing whitespace.
/ext/myandroid_r13/packages/apps/Settings/.git/rebase-apply/patch:164: trailing whitespace.
                mDisplayManager.setDisplayKeepRate(dispid, value);
Applying patch to packages/apps/SoundRecorder
Applying patch to packages/apps/VideoEditor
Applying patch to packages/inputmethods/PinyinIME
Applying patch to packages/providers/MediaProvider
Applying patch to packages/wallpapers/Basic
Applying patch to packages/wallpapers/MagicSmoke
Applying patch to prebuilt
/ext/myandroid_r13/prebuilt/.git/rebase-apply/patch:119: trailing whitespace.
    echo "flashing android images..."
/ext/myandroid_r13/prebuilt/.git/rebase-apply/patch:174: trailing whitespace.
#   vi mksdcard-android.sh
/ext/myandroid_r13/prebuilt/.git/rebase-apply/patch:188: trailing whitespace.
#   Description   : Split appart an Android boot image created
/ext/myandroid_r13/prebuilt/.git/rebase-apply/patch:192: trailing whitespace.
#                   Thanks to alansj on xda-developers.com for
/ext/myandroid_r13/prebuilt/.git/rebase-apply/patch:193: trailing whitespace.
#                   identifying the format in bootimg.h and
warning: squelched 2 whitespace errors
warning: 7 lines add whitespace errors.
Applying patch to system/core
/ext/myandroid_r13/system/core/.git/rebase-apply/patch:77: new blank line at EOF.
/ext/myandroid_r13/system/core/.git/rebase-apply/patch:48: new blank line at EOF.
Applying patch to system/extras
Applying patch to system/netd
/ext/myandroid_r13/system/netd/.git/rebase-apply/patch:663: trailing whitespace.
/ext/myandroid_r13/system/netd/.git/rebase-apply/patch:684: trailing whitespace.
#ifdef ATH_WIFI
/ext/myandroid_r13/system/netd/.git/rebase-apply/patch:710: trailing whitespace.
#ifdef ATH_WIFI
/ext/myandroid_r13/system/netd/.git/rebase-apply/patch:723: trailing whitespace.
#ifdef ATH_WIFI
/ext/myandroid_r13/system/netd/.git/rebase-apply/patch:760: trailing whitespace.
    strcpy(mBuf, "abcdefghijklmnopqrstuvwxyz");
warning: squelched 5 whitespace errors
warning: 10 lines add whitespace errors.
/ext/myandroid_r13/system/netd/.git/rebase-apply/patch:758: trailing whitespace.
Applying patch to system/vold
Applying patch to system/wlan/atheros
/ext/myandroid_r13/system/wlan/atheros/.git/rebase-apply/patch:501: trailing whitespace.
/ext/myandroid_r13/system/wlan/atheros/.git/rebase-apply/patch:511: trailing whitespace.
/ext/myandroid_r13/system/wlan/atheros/.git/rebase-apply/patch:576: trailing whitespace.
# backup EEPROM data to a file,the file name is the option,if the filename not specified,using last part of MAC address as the file name
/ext/myandroid_r13/system/wlan/atheros/.git/rebase-apply/patch:582: trailing whitespace.
sudo $IMAGEPATH/eeprom -r -f $1.epm
/ext/myandroid_r13/system/wlan/atheros/.git/rebase-apply/patch:2769: trailing whitespace.
warning: squelched 4303 whitespace errors
warning: 4308 lines add whitespace errors.
/ext/myandroid_r13/system/wlan/atheros/.git/rebase-apply/patch:36: trailing whitespace.
    printf("%s", buffer);
/ext/myandroid_r13/system/wlan/atheros/.git/rebase-apply/patch:1027: trailing whitespace.
/ext/myandroid_r13/system/wlan/atheros/.git/rebase-apply/patch:1037: trailing whitespace.
/ext/myandroid_r13/system/wlan/atheros/.git/rebase-apply/patch:2425: trailing whitespace.
#define AR6000_XIOCTL_WMI_SET_QOS_SUPP                  148
/ext/myandroid_r13/system/wlan/atheros/.git/rebase-apply/patch:2437: trailing whitespace.
#define AR6000_XIOCTL_SET_BT_HW_POWER_STATE             156
/ext/myandroid_r13/system/wlan/atheros/.git/rebase-apply/patch:2438: trailing whitespace.
#define AR6000_XIOCTL_GET_BT_HW_POWER_STATE             157
warning: squelched 4657 whitespace errors
warning: 4662 lines add whitespace errors.
/ext/myandroid_r13/system/wlan/atheros/.git/rebase-apply/patch:102: trailing whitespace.
/ext/myandroid_r13/system/wlan/atheros/.git/rebase-apply/patch:119: trailing whitespace.
    mkdir /data/system/wpa_supplicant /data/system/hostapd
/ext/myandroid_r13/system/wlan/atheros/.git/rebase-apply/patch:137: trailing whitespace.
    else
/ext/myandroid_r13/system/wlan/atheros/.git/rebase-apply/patch:155: trailing whitespace.
    fi
/ext/myandroid_r13/system/wlan/atheros/.git/rebase-apply/patch:179: trailing whitespace.
    fi
warning: squelched 11 whitespace errors
warning: 16 lines add whitespace errors.
/ext/myandroid_r13/system/wlan/atheros/.git/rebase-apply/patch:263: trailing whitespace.
/ext/myandroid_r13/system/wlan/atheros/.git/rebase-apply/patch:792: trailing whitespace.
/ext/myandroid_r13/system/wlan/atheros/.git/rebase-apply/patch:942: trailing whitespace.
/ext/myandroid_r13/system/wlan/atheros/.git/rebase-apply/patch:1013: trailing whitespace.
/ext/myandroid_r13/system/wlan/atheros/.git/rebase-apply/patch:1061: trailing whitespace.
warning: squelched 122 whitespace errors
warning: 127 lines add whitespace errors.
/ext/myandroid_r13/system/wlan/atheros/.git/rebase-apply/patch:15730: trailing whitespace.
/ext/myandroid_r13/system/wlan/atheros/.git/rebase-apply/patch:15740: trailing whitespace.
/ext/myandroid_r13/system/wlan/atheros/.git/rebase-apply/patch:15822: trailing whitespace.
/ext/myandroid_r13/system/wlan/atheros/.git/rebase-apply/patch:15832: trailing whitespace.
/ext/myandroid_r13/system/wlan/atheros/.git/rebase-apply/patch:15885: trailing whitespace.
warning: squelched 3625 whitespace errors
warning: 3630 lines add whitespace errors.
/ext/myandroid_r13/system/wlan/atheros/.git/rebase-apply/patch:12: new blank line at EOF.
/ext/myandroid_r13/system/wlan/atheros/.git/rebase-apply/patch:243484: trailing whitespace.
# new relase of compat-wireless-2.6 OR when the user updates the
/ext/myandroid_r13/system/wlan/atheros/.git/rebase-apply/patch:243502: trailing whitespace.
  @$(MODPROBE) -l ath3k
/ext/myandroid_r13/system/wlan/atheros/.git/rebase-apply/patch:243540: trailing whitespace.
/ext/myandroid_r13/system/wlan/atheros/.git/rebase-apply/patch:243617: trailing whitespace.
  @echo
/ext/myandroid_r13/system/wlan/atheros/.git/rebase-apply/patch:243698: trailing whitespace.
warning: squelched 2585 whitespace errors
warning: 2590 lines add whitespace errors.
/ext/myandroid_r13/system/wlan/atheros/.git/rebase-apply/patch:15: trailing whitespace.
/ext/myandroid_r13/system/wlan/atheros/.git/rebase-apply/patch:78: trailing whitespace.
endif
/ext/myandroid_r13/system/wlan/atheros/.git/rebase-apply/patch:107: trailing whitespace.
ATH_ANDROID_BUILD_FLAGS += -DATH6KL_CONFIG_HIF_VIRTUAL_SCATTER
/ext/myandroid_r13/system/wlan/atheros/.git/rebase-apply/patch:108: trailing whitespace.
endif
warning: 4 lines add whitespace errors.
/ext/myandroid_r13/system/wlan/atheros/.git/rebase-apply/patch:11544: trailing whitespace.
  REG_RULE(2457, 2482, 20, 3, 20,
/ext/myandroid_r13/system/wlan/atheros/.git/rebase-apply/patch:11545: trailing whitespace.
  NL80211_RRF_PASSIVE_SCAN |
/ext/myandroid_r13/system/wlan/atheros/.git/rebase-apply/patch:11547: trailing whitespace.
  REG_RULE(2474, 2494, 20, 3, 20,
/ext/myandroid_r13/system/wlan/atheros/.git/rebase-apply/patch:11548: trailing whitespace.
/ext/myandroid_r13/system/wlan/atheros/.git/rebase-apply/patch:11549: trailing whitespace.
  NL80211_RRF_NO_IBSS |
warning: squelched 169 whitespace errors
warning: 174 lines add whitespace errors.
Applying patch to system/dispd
/ext/myandroid_r13/system/dispd/.git/rebase-apply/patch:53: trailing whitespace.
LOCAL_CFLAGS :=
/ext/myandroid_r13/system/dispd/.git/rebase-apply/patch:246: trailing whitespace.
/ext/myandroid_r13/system/dispd/.git/rebase-apply/patch:423: trailing whitespace.
        LOGE("Unable to listen on fd '%d' for socket '%s': %s",
/ext/myandroid_r13/system/dispd/.git/rebase-apply/patch:454: trailing whitespace.
     * Bootstrap
/ext/myandroid_r13/system/dispd/.git/rebase-apply/patch:877: trailing whitespace.
    return 0;
warning: squelched 6 whitespace errors
warning: 11 lines add whitespace errors.
/ext/myandroid_r13/system/dispd/.git/rebase-apply/patch:175: trailing whitespace.
    { "sii9022", handle_sii9022_event },
/ext/myandroid_r13/system/dispd/.git/rebase-apply/patch:212: trailing whitespace.
/ext/myandroid_r13/system/dispd/.git/rebase-apply/patch:130: new blank line at EOF.
/ext/myandroid_r13/system/dispd/.git/rebase-apply/patch:242: trailing whitespace.
    { "sii902x", handle_sii9022_event },
/ext/myandroid_r13/system/dispd/.git/rebase-apply/patch:284: trailing whitespace.
* Uevent Handlers for dvi plugin/plugout
/ext/myandroid_r13/system/dispd/.git/rebase-apply/patch:299: trailing whitespace.
/ext/myandroid_r13/system/dispd/.git/rebase-apply/patch:153: new blank line at EOF.
/ext/myandroid_r13/system/dispd/.git/rebase-apply/patch:24: trailing whitespace.
    { "switch", NULL, handle_switch_event },
/ext/myandroid_r13/system/dispd/.git/rebase-apply/patch:26: trailing whitespace.
    { "sii902x", "/devices/platform/sii902x.0",handle_sii9022_event },
/ext/myandroid_r13/system/dispd/.git/rebase-apply/patch:139: trailing whitespace.
/ext/myandroid_r13/system/dispd/.git/rebase-apply/patch:218: trailing whitespace.
/ext/myandroid_r13/system/dispd/.git/rebase-apply/patch:307: trailing whitespace.
    send_msg_with_code(enabled ? InterfaceConnected: InterfaceDisconnected,
/ext/myandroid_r13/system/dispd/.git/rebase-apply/patch:334: trailing whitespace.
    send_msg_with_code(enabled ? InterfaceEnabled: InterfaceDisabled,
/ext/myandroid_r13/system/dispd/.git/rebase-apply/patch:359: trailing whitespace.
        rc = send_msg_with_code(disp_connected_get(i) ? InterfaceConnected: InterfaceDisconnected,
warning: squelched 35 whitespace errors
warning: 40 lines add whitespace errors.
Success: Now you can build android code for FSL i.MX platform
hkbdm@ubuntu:/ext/android_bak/r13$
what happens ?
why it show "Success: Now you can build android code for FSL i.MX platform ''
SergioSolis
Hello Quand Guo,
You did not get any errors patching it, you just got "warnings", that is why it is able to patch it.
Most probably there is a corrupt file, you would need to redo it to check if it still shows the same warnings.
Were you able to continue building android?
