MVF61NN151CMK10/NAND flash memory and SPI flash memory
soichiyamamoto
Contributor V
Hello
I use MVF61NN151CMK10.
NAND flash memory and SPI flash memory wants to uses  MT29F4G08ABADAWP-IT:D and M25P128-VMF6TPB.
I think that will be no problem with this method.
Is this all right?
Please give me comment.
soichi yamamoto
karina_valencia
NXP Apps Support
NXP Apps Support
ioseph_martinez can you review this case and provide follow up?
soichiyamamoto
Contributor V
Hi Karina Valencia Aguilar,
Thank you very much.
Yes
soichi yamamoto
ioseph_martinez
Hi Soichi-san,
I have access to the SPI NOR memory but not the NAND memory datasheet.
I checked SPI NOR memory datasheet seems fine. I expect is possible to use this device but you would need to do some testing to confirm this 100%
Regarding the NAND memory I cannot comment since I don't have access to that memory.
Which device do you plan to use for system boot, the NAND or the SPI-NOR?
Ioseph
