setting of RTCS option not working
Question asked by vines on Jul 4, 2013
Latest reply on Dec 6, 2013 by Martin Latal
Hi All,
I have a question in setting the value for OPT_RETRANSMISSION_TIMEOUT. It seems to be not working in actual testing.
Here is a snippet of what I am trying to do:
opt_value = 500;
error = setsockopt(gSock, SOL_TCP, OPT_RETRANSMISSION_TIMEOUT, &opt_value,sizeof(opt_value));
if (error != RTCS_OK)
     os_task_block();
opt_value = 0;
error = getsockopt(gSock, SOL_TCP, OPT_RETRANSMISSION_TIMEOUT, &opt_value,&opt_length);
     os_task_block();
When I get the value, it did show 500ms. However during actual testing, the retransmission of packet is still not the desired value.
During actual testing retransmission happens whenever client doesn't ack the data on the network layer. I am doing this purposely to see how long will be the retransmission. On the RTCS manual , it states there:
After a connection is established, RTCS determines the retransmission timeout, starting from this initial value.
I wonder if the RTCS stack automatically re-adjust this value before sending?
Thanks.
